Author Topic: 3 amp fuse blowing on heat pump  (Read 9395 times)
JO42281
  • OWF Model: H5
« on: October 21, 2016, 10:46:16 PM »
So I discovered tonight that the 3amp fuse coming from the 24vac xfm in my heat pump blows when I turn on my second t stat for my log burner! Everything work fine for the heat pump t stat I have a 24vac relay isolating the two t stats. Ran fine last year. Anyone have anyideas?
Kubota 9000
Kubota 6800
Case 850
Silverado 2500
Silverado 1500
Ford F-250
Stihl ms290
Stihl ms362
Piedmont SC
Re: 3 amp fuse blowing on heat pump
« Reply #1 on: October 21, 2016, 11:09:20 PM »
If the second t stat uses the power supply the 3 amp fuses protects then my guess is a bad t stat with what I have to go on from your OP.
JO42281
  • OWF Model: H5
« Reply #2 on: October 22, 2016, 05:24:19 AM »
Would there be a way to test it to see if it's bad with my volt meter?
Kubota 9000
Kubota 6800
Case 850
Silverado 2500
Silverado 1500
Ford F-250
Stihl ms290
Stihl ms362
Piedmont SC
« Reply #3 on: October 22, 2016, 08:46:21 AM »
You can if it has an ohm meter.
Easiest thing would be to disconnect any wires from the back of the second t stat but leave the C and R (power) wires connected, install a new fuse and see what happens, if the fuse blows again, its something in the t stat, replace it.
If the fuse doesn’t blow hook the wires back up, then disconnect them at the other end of the run, if the fuse blows you have a dead short in the wires, if not then what ever they are hooked to is causing the problem.
JO42281
  • OWF Model: H5
« Reply #4 on: October 22, 2016, 10:13:26 AM »
Thanks I will do it! :post:
Kubota 9000
Kubota 6800
Case 850
Silverado 2500
Silverado 1500
Ford F-250
Stihl ms290
Stihl ms362
Piedmont SC
JO42281
  • OWF Model: H5
« Reply #5 on: October 28, 2016, 08:29:21 PM »
I got my wiring issue fixed today. I ended up finding a chewed up spot in the wiring repaired all that and it fixed it right up!
Kubota 9000
Kubota 6800
Case 850
Silverado 2500
Silverado 1500
Ford F-250
Stihl ms290
Stihl ms362
Piedmont SC
« Reply #6 on: October 28, 2016, 10:47:33 PM »
Cool beans :thumbup:
