Author Topic: recommend induction motor  (Read 7283 times)
oldchenowth
  • OWF Brand: WoodDoctor
  • OWF Model: HE 5000
« on: October 23, 2016, 05:10:46 PM »
I have a Wood Doctor HE 5000 and the induction motor has gone out again.  the original seems to be a Fasco a n LR 6319.  That is the only thing close to a model number I can see on the label.  Last  years fan was  a Fasco D-130.  It worked good most of the season but started to peter out near the end.  So I bought a Fasco D-109.  Huge failure on my part there.  When the 109 runs it works great then apparently the thermal protect kicks in and nothing for 10 - 15 minutes.  The 130 was good but always seemed to labor.
The original motor worked great for 3 seasons before pooping out, had 1600 rpm.  That extra 100 r's make a big difference over the 130.
I can't seem to find the LR6319.  Any recommendations for a replacement Fasco or other wise that may last longer than 1 season?  And have really good draw at around 1600 - 1750 rpm.
Any help would be appreciated.  Back on propane until I get a new motor.
Rich
Re: recommend induction motor
« Reply #1 on: October 23, 2016, 06:02:51 PM »
Rich
you might look in (if you are in America) Grainger or (Canada) acklandgrainger. they have both fasco and Dayton products that you might find helpful   both have online books to look through
BoilerHouse
  • OWF Brand: Home Built
« Reply #2 on: October 24, 2016, 06:41:28 AM »
Is all the wiring up to par?  This will be motor #4.
They look like they are available through E Bay.
http://www.ebay.com/itm/Fasco-Motors-LR6319-115V-VOLT-2-2-AMP-1550-RPM-/272186982151?_trksid=p2349526.m2548.l4275
Muskoka, Ont
« Reply #3 on: October 24, 2016, 07:01:38 PM »
The description doesn't match the title. I would check with the seller before buying to make sure it is really the 115v version you will get.
