Author Topic: fire box thickness  (Read 7147 times)
dbarboy73
fire box thickness
« on: February 28, 2011, 06:17:52 PM »
going to start building a new owb I have a gasline pipe that is 1 inch thick with 1 inch thick plates for both ends.  Is this to thick  for the firebox or should i use a diffrent thickness?
rosewood
Re: fire box thickness
« Reply #1 on: February 28, 2011, 07:20:49 PM »
that will be the cats meow,i used 3/4 thick round 3'dia by 5' with a 1''end plate on rear. holds heat for a longer time then thinner stock. bigger the better!
dbarboy73
« Reply #2 on: February 28, 2011, 07:39:51 PM »
nice, thanks for the info
« Reply #3 on: March 01, 2011, 07:39:49 AM »
 The thicker you make the firebox the longer it takes to transfer heat through it and into the water. If I was building a furnace I would make sure the water jacket is really thick. Most of the mild steel furnaces that I have seen leak have been at the bottom of the water jacket where sediment built up.
