Author Topic: Hot coals falling out  (Read 6656 times)
Bluegrass Wood Burner
  • OWF Brand: Ozzark Biomass
« on: December 08, 2016, 06:11:12 AM »
im having problems with hot coals falling out of firebox when I open the door or when I'm leveling down the coal bed. When the wind is blowing there's a danger here of leaves and my stack of firewood of catching on fire. I keep buckets of water nearby and wet the area down after I'm done filling. Any of you guys have a simple remedy for this. I attached a picture of my firebox when it was new.
South central Kentucky
Ford F-150
16 ft tandem trailer
3000# winch
Husqvarna 142
Husqvarna 460 rancher
6ft spud bar
Poulan 3314
22 ton lowes splitter
Timberline sharpener
"Worn out body"
Re: Hot coals falling out
« Reply #1 on: December 08, 2016, 06:45:27 AM »
I couldn’t get the picture to expand, but I’m guessing it might be a problem no matter what since the firebox is flat the entire length with no ledge at the front to hold the coals in.
« Reply #2 on: December 08, 2016, 07:01:11 AM »
That's the problem. I thought about having a ledge make for the front but it might distract the draft blower. Also thought about having a large pan made to lay on the ground underneath before I open to catch the coals, but if wing was blowing some would still go astray. Though My stove is only 2 years old  it's is one of the old style boilers similar to Taylor's and some of these issues have no remedy. Just thought I would try and find a solution. You guys have helped me figure a few other things out. And I appreciate it.😊
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
« Reply #3 on: December 08, 2016, 07:06:40 AM »
How high up is the air inlet? If you could put a steel spacer across the front, I would think it would help a lot.
« Reply #4 on: December 08, 2016, 07:30:20 AM »
I may have 2-3 inches. I guess that much would help. Any would be better than none. I never put word in it without at least one hot coal falling out. I usually just reach down and pick it up and throw it back in, with gloves on obviously. But when the wind is blowing like it is today those coals can get away from you before you can grab them. We have a lot of shade trees and there's always leaves swirling around. If the leaves ignited then blew under my wood pile it would be bad for me. Buckets of water are always close by for that reason. I may get me a fire exteniguisher and mount it close by. The fire is our friend when it comes to heating our home , but it can quickly become our enemy in this case. I had a neighbor who lost his barn woodpile and boiler because of a similar event.
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
shepherd boy
« Reply #5 on: December 08, 2016, 12:29:55 PM »
I have heard of people with Taylor stoves using a piece of railroad rail cut the right length and laying it in the front of the firebox.  But you are right on being a fire danger. Almost always see an ash pile in front of a Taylor and know it could be trouble.
Let the youngin's have it
 Gettin' old and lazy
« Reply #6 on: December 08, 2016, 03:34:01 PM »
If you had too you could always cut a little notch in it for air flow.
« Reply #7 on: December 08, 2016, 03:47:41 PM »
I would think a piece of angle iron would work. If it tips over, weld two together to make a tee. (or use two flat bars to make a tee. Then you can just pull it out when cleaning the ashes out.
« Reply #8 on: December 08, 2016, 03:56:13 PM »
Great idea. The angle iron wouldn't be so tall to block my draft blower. The train rail sounds good but I'm afraid it's to tall and would block the air flow.
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
fireboss
« Reply #9 on: December 08, 2016, 06:18:21 PM »
What about keeping the area free of combustibles and put some 3/4 stone down  so if any thing falls out it won't hurt anything!
« Reply #10 on: December 08, 2016, 08:38:20 PM »
I keep a leaf blower handy at all times. I blow off any debri that has blown up around door before I start filling. The rock or maybe even sand would be a good idea.
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
