Author Topic: setting differential  (Read 7962 times)
blmike
  • OWF Brand: portage & main
  • OWF Model: bl2840
« on: December 12, 2016, 05:44:58 AM »
What are the benefits of setting it low or higher #I think mine came set at 6 now at 8.
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
Re: setting differential
« Reply #1 on: December 12, 2016, 03:56:53 PM »
  I change mine a few times during the season. Smaller differential (7 or 8) in the fall and spring when demand is low to prevent too long of an idle and letting the coals go cold enough to not relight (but creosote build up becomes an issue) , and a larger differential (13 or 14) when the cold weather starts. The larger the diff the longer the burn time which should help keep creosote under control. These settings work well for me but may not work for others.
blmike
  • OWF Model: bl2840
« Reply #2 on: December 12, 2016, 04:50:03 PM »
Do you notice a change in the amount of wood burned when going to bigger #?
Crow
  • Eastern Ontario
« Reply #3 on: December 13, 2016, 06:03:28 AM »
 I would say yes, but I am making the change from a mild weather temp setting which requires less wood in the first place to get my 12 hour burn time.
 Have you tried different settings?  Might be time for you to experiment a little bit and find what works best for your set-up.
