Author Topic: New R&D chip burner  (Read 10553 times)
shepherd boy
  • OWF Model: C375
New R&D chip burner
« on: December 21, 2016, 12:29:39 PM »
Thought you guys might enjoy some pictures of a chip burner Heatmaster is testing. Burning chips out of a grinder so far, potential for all sorts of biomass. Heating two 12,000 sq ft shops (24,000 sq ft total), 24' tall. No blockages after several months burning, feed system seems to work very well. 500,000 btu.
Not available to public- yet.
« Last Edit: December 21, 2016, 12:38:50 PM by shepherd boy »
Let the youngin's have it
 Gettin' old and lazy
shepherd boy
  • OWF Model: C375
Re: New R&D chip burner
« Reply #1 on: December 21, 2016, 12:31:13 PM »
Outside picture.
« Last Edit: December 21, 2016, 12:37:29 PM by shepherd boy »
shepherd boy
  • OWF Model: C375
« Reply #2 on: December 21, 2016, 12:32:55 PM »
pumps
shepherd boy
  • OWF Model: C375
« Reply #3 on: December 21, 2016, 12:36:21 PM »
Bin is not finished, sides are temporary metal. Uses four 2,000 CFM blowers with coils to heat the buildings.
This is all from waste wood they generate in the shops. Free heat!
Roger2561
« Reply #4 on: December 21, 2016, 12:55:32 PM »
Is this geared toward commercial use or will it work in a home too?  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
shepherd boy
  • OWF Model: C375
« Reply #5 on: December 21, 2016, 12:59:36 PM »
Would be aimed toward commercial market. Very few homes would need that many btu's. I guess it could go residential at some point but cost would be a factor!
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« Reply #6 on: January 23, 2017, 12:03:22 AM »
Would love to have a residential size of this.  I would literally chip all my wood into my dump trailer and fill through a hopper I could load with my tractor.  That I would love.
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
« Reply #7 on: January 23, 2017, 12:10:06 AM »
Not likely to see a low cost residential unit because scaling it down doesn't reduce the cost enough. All the expensive parts are pretty much same on a small or large unit.
aarmga
  • Central Wisconsin
« Reply #8 on: January 23, 2017, 01:26:03 AM »
I'm sure you're right, maybe I'll build one someday.  Wonder how the coal boilers would do with a load of wood chips.  I have more than I know what to do with.
Stihl 211 - 16"
JD 1025r with FEL
« Reply #9 on: March 03, 2017, 02:51:42 PM »
Auger finally in place to feed straight off the grinder. 500,000 btu's 24 hrs a day, no more hand loading. So nice.
« Last Edit: March 03, 2017, 03:07:58 PM by E Yoder »
aarmga
  • Central Wisconsin
« Reply #10 on: March 04, 2017, 08:35:16 AM »
Pretty great!
Stihl 211 - 16"
JD 1025r with FEL
NaturallyAspirated
  • OWF Model: M250
  • Golfing, snowmobiling fool!
    • http://www.nealmastel.com
« Reply #11 on: March 14, 2017, 04:55:56 PM »
So this would be along the lines of an LEI or Peltor, like $35-$40k?
Neal
« Reply #12 on: March 14, 2017, 07:41:06 PM »
Depending on what you do for a bin I'd guess between 30-40K. If it were installeed in a warm location would eliminate the need for the insulated housing over the auger/feed system which would lower the total. In this case it was all outside.
I'm not real familiar with the models you mentioned. I've watched a few videos of the LEI unit and I think this one would handle rougher bigger fuel. But that's just a guess as I've never seen it up close.
