Author Topic: Got a qoute for a CB 5036  (Read 17681 times)
TLuckoski
  • OWF Model: 5036
« on: March 10, 2011, 06:39:49 PM »
CB 5036,125 feet of  CB thermo pex,water  pump heat exchanger  all the clamps termanation caps etc etc etc. Every thing I need from start to finish. Price $9800.00 what do you guys think??????????
Alan
Re: Got a qoute for a CB 5036
« Reply #1 on: March 10, 2011, 08:22:34 PM »
is that installed
Alan  Marydale ky
TLuckoski
  • OWF Model: 5036
« Reply #2 on: March 11, 2011, 01:45:28 PM »
$600.00 Extra for the install. As long as I dig the trench.
« Reply #3 on: March 11, 2011, 04:26:48 PM »
 The list price for that unit is $6,160.  http://www.centralboiler.com/models.php That means they are pricing the parts at $3, 640. Without knowing the situation that seems a bit high unless you have some unusual hookup. On a normal install using 125 ft of pipe I would normally charge $1,825 for parts and labor not including the ditch. Of course the piping I use isn't as good or as costly as what they normally do.
Alan
« Reply #4 on: March 11, 2011, 07:42:00 PM »
two years ago  that is what i gave  for 5036 and for the install
Alan  Marydale ky
MTJAG
  • OWF Model: CL5036
« Reply #5 on: March 31, 2011, 08:00:09 AM »
I just ordered a 5036 and my quote was $8550, but that was only 30' of Thermopex.  It did include everything else including two heat exchangers.  Also, it will be about $600 for the install.  I am digging the trench, pouring the slab, and providing the conduit for wire.
Ridgekid
« Reply #6 on: April 02, 2011, 09:13:34 AM »
I also ordered the CL5036. Heres my breakdown costs:
Cl 5036 $6160
85' Thermo-pex @ 12.00/ft= $1020
Heat Exchanger $291
Taco pump $213
40' Pex pipe (to make connections to heat exchanger/CL 5036) - $64
Misc Fittings/Insulation for pipe at unit $50
Aquastat and thermo valve-$150
Chimney cap-$76
Power Cord for pump $5
Two Thermopex caps $40
Installation $750 (2 guys coming 70 miles away)
Shipping $ 210
Tax (6%) $540
Grand Total=$9569
Note on installation. I dug the trench and provided the power for the unit. I ran 12/2 wire inside 3/4 plastic pipe. Although not required, I poured the foundation. Also installed a water fill valve in the house. (Cost $180)
My son ordered a CL4030- In order to get both delievered and installed same day, I have to provide a "lifting device" to get the units off his trailer. His trailer can only handle lifting one unit, but he can haul two. (Something about placement on the trailer when hauling one) Cost to be determined. Edit- Cost was $165
Aquastat- I have forced air.  If my thermostat calls for heat it will turn on the fan only if water temp from boiler is at least 160F. If not, it will turn on the heatpump.
Thermo valve- If the water drops below 150F, it will recirc it back to the boiler.
We declined the $500 labor warranty. Unit will be filled and tested before he leaves site.
(Modified the Cost to show items I missed- Thanks MTJag) Final Cost remains the same.
Mofided April 25th- Added actual cost to lift OWB to pads and changed Aquastat and thermo valve temps.
« Last Edit: April 25, 2011, 06:20:43 AM by Ridgekid »
MTJAG
  • OWF Model: CL5036
« Reply #7 on: April 02, 2011, 11:16:04 AM »
Here's my quote for the 5036 that will be delivered next week:
quote
1650   inhibitor                   1    $39.07
224   Kit, ISO Flange   1    $36.25
198   ball value   8.82   1    $8.82
1330   Pex adapt   3.54   4    $14.16
1311   Central pex   121.91   1    $121.91
5636   HeatX 50 plate   473.35   2    $946.70
2443   cap, thermopex   19.2   2    $38.40
CL5036         1    $6,160.00
10508   chimney 48"   1    $141.96
10509   clamp chimney   1    $4.88
thermopex   pipe   11.5   30    $345.00
Subtotal             $7,857.15
Tax         2.9%    $227.86
Delivery             $500.00
total             $8,585.01
« Reply #8 on: April 02, 2011, 09:03:38 PM »
Cl 5036 $6160
Heat Exchanger $291
Taco pump $213
Chimney cap-$76
Shipping $ 210
Tax (6%) $540
Grand Total=$9569
Aquastat- I have forced air.  If my thermostat calls for heat it will turn on the fan only if water temp from boiler is at least 150F. If not, it will turn on the heatpump.
Thermo valve- If the water drops below 140F, it will recirc it back to the boiler.
Why would they have an additional cost for labor warranty?  Do they not guarantee the work they do or is this a labor warranty for the furnace itself.  If so isn't that covered by the warranty on the furnace?
Ridgekid
« Reply #9 on: April 03, 2011, 07:56:40 AM »
yoderheating-
It would take a technician 3 hours round trip for a service call. Not including service time. $500 would cover unlimited amount of trips for one year. (Replacing parts and or fixing leaks on piping)
The warranty stands on all parts. This would just mean I would have to replace them. Since I'm pretty handy I told him I could handle the repairs, he can ship me the part.
« Reply #10 on: April 03, 2011, 06:56:19 PM »
 Okay, I know different companies do it different ways. I do all service work for free so long as the parts are covered under the furnace warranty. On installation work I do a one year parts and labor warranty.
 I think you will find that it is very unlikely anything will break in the first year anyway.  Also, most of the brands I have looked at make it fairly easy to replace parts. If you have a basic understanding of how to use a screwdriver and a wrench you can replace most of the parts.
plumb bob
  • OWF Model: CL 5036
  • still green
« Reply #11 on: April 25, 2011, 01:29:11 PM »
$5960.00 + tax
free delivery
owb only
Ridgekid
« Reply #12 on: April 25, 2011, 01:55:38 PM »
You stole it??? :lmao
My only recommendation is not to skip on the underground pipe. With thermopex I only have a 1 degree loss on over 80 feet. Your in Wisconsin, so I know this will be important to you in the winter months.
Good luck with the install. We are all here to help you if you have questions.
« Last Edit: April 25, 2011, 04:27:03 PM by Ridgekid »
plumb bob
  • still green
« Reply #13 on: April 25, 2011, 02:50:01 PM »
My only recommendation is not to skip on the underground pipe. With thermoflex I only have a 1 degree loss on over 80 feet. Your in Wisconsin, so I know this will be important to you in the winter months.
Yeah I thought it was a good deal. I'm guesssing about $1500-2000 additional materials.And yes, thermopex will be used.
woodywoodchucker
  • OWF Brand: cental boiler
  • OWF Model: classic 5036
« Reply #14 on: April 25, 2011, 03:06:32 PM »
What kind of space are you heating? how any sf? 1800 Im heating and the 5038 is 10 hour burns max in the coolest maine weather.
