Pages: [1] 2 3
Author Topic: Wood tally  (Read 26184 times)
Wood tally
« on: March 03, 2017, 06:32:05 PM »
Checked out my supply today, gotta say I am quite surprised. Started the burning year with 29 full cords and only 15 left and the season is not over. :bash:
Re: Wood tally
« Reply #1 on: March 03, 2017, 08:57:33 PM »
How many times per day do you load your stove?
Re: Wood tally
« Reply #2 on: March 03, 2017, 10:13:37 PM »
Ouch, I think I ran that much thru the G400 last year. You guys have had some really frigid weather up that way though, our coldest all winter was -13.
Re: Wood tally
« Reply #3 on: March 04, 2017, 07:24:59 AM »
I'm pretty busy for the next couple of weeks but when I get back I would like to take a close look at your stove, I know you said earlier that you seemed to be burning a lot of wood , something isn't right.
Do you have a good stack temp gauge you could slide into the stack just above the breach?
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
Re: Wood tally
« Reply #4 on: March 04, 2017, 07:39:41 AM »
Seems like a lot of wood to me!  I burned 9 cord this winter in Wisconsin
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
Re: Wood tally
« Reply #5 on: March 04, 2017, 08:46:36 AM »
It is hard to say if it is a lot of wood without knowing what is being heated.
BIG AL
  • OWF Brand: Heatmaster SS
  • OWF Model: G 200
Re: Wood tally
« Reply #6 on: March 04, 2017, 09:07:11 AM »
I lit our boiler about mid October and I can say we have burned 5 cord as of today. I have 3+ left so I would say going into March we should be good. I would love to see what our g-200 could do if our house had insulation or decent windows.
SE Mass
Re: Wood tally
« Reply #7 on: March 04, 2017, 10:34:28 AM »
Approximately 3800 sq ft very well insulated farmhouse. 1100 sqft shop well insulated, with radiant.
40 ft run too shop, 80 ft run too house, Logstor too both.
Re: Wood tally
« Reply #8 on: March 04, 2017, 10:42:44 AM »
Huh, if it was anything but Logstor I’d be saying check for heat loss in your underground lines…..
Re: Wood tally
« Reply #9 on: March 04, 2017, 03:49:56 PM »
I am going to core a hole in my garage slab this week hopefully to see if Insulation board is wet. Hopefully missing any tubing.
Re: Wood tally
« Reply #10 on: March 04, 2017, 04:59:29 PM »
I'm heating 2800 sqft 220 year old house with decent insulation. Just cleared 6 cords heating since October 22. 14 cords is pretty nutty with that heat load. I'm not sure if it's even possible to water log xps insulation. I think I would put a hour meter on each of your systems and see where your heat is going. The logstor isn't stealing it. X2 on the stack temp measurement too to see if your blowing the heat out the stack.
Re: Wood tally
« Reply #11 on: March 04, 2017, 05:28:35 PM »
I think I am at around 5-6 cords (~75% red oak, 25% boxelder) since the beginning of December. before that I burned a bundle of slabs and other unstackable wood that I had built up. I really didn't notice any difference in wood usage when I switched from the G200 to the G100.
I still have home made lines from about 14 years ago which I am not sure how good they are. I used 1" Kitec put 3/8" pipe insulation on it and then wrapped with one layer of 3/8" bubble foil insulation. Then put in 3" drain tile and wrapped the outside with sheet plastic and taped the seam. They run about 150'
The supply and return pipes are in separate drain tiles.
I am thinking about putting in PerformaFlex Ultra or Rehau Insulpex pipe this year but would have to move the boiler because it would be too hard to run in the existing pipe path.
Re: Wood tally
« Reply #12 on: March 04, 2017, 06:30:14 PM »
Stack temp is running 275 to 300.
House and garage both need And have HRV,s
« Last Edit: March 04, 2017, 06:32:15 PM by coolidge »
Re: Wood tally
« Reply #13 on: March 04, 2017, 07:12:27 PM »
I think I'm at about 7 cords mixed hardwood in my G100. A smidge more than last year. Colder I think.
But I'm heating way more than a G1 should handle. Runs it wide open a lot.
Re: Wood tally
« Reply #14 on: March 04, 2017, 08:29:01 PM »
Doesn’t sound like its in the stove then, can you check supply and return temps on each run to at least narrow down whats pulling that much load?
Pages: [1] 2 3
