Author Topic: Central Boiler damper solenoids  (Read 11043 times)
Buckeyenut
  • OWF Model: 5036
« on: March 06, 2017, 04:39:23 PM »
Just wondering if anyone else has problems with these solenoids lasting. My 5036 is only been running a total of 9 months in the past two years and I've already had to replace 2 of these damper solenoids. Is there another solenoid to use other than the one central boiler sells? Am I doing something wrong? I scrap any creosote away as it starts to build up so it doesn't build around the damper opening. Any suggestions appreciated?
fireboss
Re: Central Boiler damper solenoids
« Reply #1 on: March 06, 2017, 06:09:32 PM »
I am still using the original one on my 6048, never had a issue. Some times it make a humming noise ,that means it's not good contact so I spray it with WD 40 and good for 6 months or so !
Pointblank
  • OWF Model: Classic Edge 550
« Reply #2 on: March 06, 2017, 06:17:34 PM »
Not sure what could be happening. Maybe erratic voltage?  Ive never had a problem with them. Got 2 seasons on my Edge now with no problems and before that I ran a 5648 for 13 years on the original solenoid.
Minnesota
« Reply #3 on: March 06, 2017, 09:35:33 PM »
I ran the solenoids on my homemade that Woodmaster used on theirs, never changed one in 15 years. I’m betting the ones I used are probably the same as the ones CB used as well as a slew of other companies. Could just be bad luck that you got a few faulty ones in a row.
« Reply #4 on: March 06, 2017, 10:04:41 PM »
If they get stuck and can not pull in they will burn up in a few minutes. At full stroke they draw something like 5 amps and seated less than 1/2 an amp.
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« Reply #5 on: March 06, 2017, 10:59:47 PM »
Ground that stove!!!
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
stryker
  • OWF Model: CL 6048, ECL 3200, Maxim M255PE
« Reply #6 on: March 20, 2017, 07:57:31 PM »
Make sure your not getting air blowing down the chimney and out the damper.  This can cause a solenoid to go bad very quickly.
