Author Topic: Fire drum wear and tear?  (Read 8188 times)
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« on: March 06, 2017, 11:15:48 PM »
What's everybody's Honest opinion on the wear and tear to the fire drum by letting the fire go out completely and cooling the fire drum  to outside temperature and relighting  it on the weekends.  Seeing as metal expands and contracts especially with the amount of heat we add initially at startup, does this cause premature wear?  I guess I am thinking of it as the same as a gasoline engine. Running it for a long period of time and keeping it at temperature causes less wear on the engine then letting it warm and cool off by taking it on short trips and letting it cool off
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
f150bft
  • OWF Model: H-4
Re: Fire drum wear and tear?
« Reply #1 on: March 07, 2017, 06:02:29 AM »
I would think that if you re-lit the fire and just added a little wood at a time to bring the temp up slow it wouldn't matter. But that's just my opinion.
Husqvarna Rancher 460
Homelite Super XL
1992 F150
1970 Wheel Horse Raider 12
1966 Wheel Horse Lawn Ranger
N.E. Tennessee
aarmga
  • Central Wisconsin
« Reply #2 on: March 08, 2017, 07:22:09 PM »
Figured I'd have more responses than this!  Thanks f150.
Stihl 211 - 16"
JD 1025r with FEL
« Reply #3 on: March 08, 2017, 07:56:58 PM »
An engine isn't really an accurate comparison to a wood boiler. The engine needs time for the oil to lube everything. A wood furnace should be designed to expand and contract with the heat.
Only thing I could see about letting it set cool is if you had a mild steel unit a d let moisture collect in it and rot it out.
A lot of boilers are run with storage where they run full bore and burn the whole load of wood, then shutdown for quite a while. Works fine.
« Reply #4 on: March 08, 2017, 08:18:41 PM »
But from an efficiency standpoint running steady with no shutdown would be ideal. A hot furnace burns cleanest .
Furnaces usually leak from rust from condensation, pinholes (lack of treatment,sludge buildup) or stress cracking (poor design or wrong material).
At least that's what I've seen.
