Author Topic: Is this splitter worth messing with?  (Read 10789 times)
« on: March 25, 2017, 01:30:21 PM »
I have a Speeco 35 ton splitter that works good but it slow and a real pain working with larger logs. I came across this but not sure if will just end up being a pile of scrap. https://madison.craigslist.org/grd/6011143106.html
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
Re: Is this splitter worth messing with?
« Reply #1 on: March 25, 2017, 04:14:19 PM »
Run away!
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
« Reply #2 on: March 25, 2017, 10:21:50 PM »
Lol, I think you are right. It was the 6 way wedge that got me looking at it.
I think I will build a platform for the speeco to hold wood to make it easier to split. Or maybe just get an upside down splitter for on the Toolcat.
aarmga
  • Central Wisconsin
« Reply #3 on: March 26, 2017, 12:07:32 AM »
You have a tool cat!!??  I'm jealous!  I know one can build a splitter that uses external hyd. power for under a grand.  Having an engine/pump brings the price up 4-600.  If you have one of those awesome tool cats I'd build one!
Stihl 211 - 16"
JD 1025r with FEL
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
  • Southeast Michigan
« Reply #4 on: March 26, 2017, 07:31:30 AM »
If it works and the cylinder is good, its defiantly worth it. Especially if you know how to fabricate and wrench on things.
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Stihl 036pro, 362c, 064
Husk 385,570
Shindiawa 416
Griffin 14' Dump
« Reply #5 on: March 27, 2017, 01:14:43 PM »
My personal opinion, which may not be worth a hill of beans.
1: angle on the u-joints in the one picture look to be a bit extreme, may have awful vibration issues while running at speed under  load.
2: I beam looks to be way too light for a 6 way wedge and the size of the hydraulic cylinder, may resemble a pretzel in short order.
3: six way wedge is made incorrectly, with the lower one bevel side up when it starts to split its going to wedge that piece of wood into the top one. Simple fix would be to move the top one back at least a few inches.
It might have $500 worth of hoses, pumps and cylinder on it though, a good welded cylinder isn’t cheap even thru the surplus centers.
« Last Edit: March 27, 2017, 01:36:12 PM by mlappin »
« Reply #6 on: March 27, 2017, 01:22:33 PM »
Oh boy, sure doesn't appear to be osha approved either ha ha! The 6 way should be removable or adjustable as well.
« Reply #7 on: March 27, 2017, 01:41:43 PM »
That as well. From personal experience with the firewood processor if your going with a multiple split wedge, you want it adjustable somehow or you will end up with tons of wood slivers when that multiple wedge is just skimming a piece of wood as it goes thru.
« Reply #8 on: March 27, 2017, 02:56:37 PM »
What no comment on the OSHA approval, someday I'll get a pic of my old home made dinosaur, you will get a chuckle, between the bungee cords and dog chain it works pretty good!
BIG AL
  • OWF Brand: Heatmaster SS
  • OWF Model: G 200
« Reply #9 on: March 27, 2017, 04:45:57 PM »
Never owned a store bought splitter. Maybe only ever used one once or twice. Seemed like a lot of money for something I could build myself. Finding the parts is 90% of the project and knowing how to fabricate is the rest of it. We have buit several of them from salvaged pistons and surplus steel parts. Finding a good 2 stage pump can be difficult , but they aren't that bad at Surplus Center. Sometimes if you can find a good carcas that someone else has collected the parts for you you could do a lot with it. Personally having run 2 different splitters we built in the past off of either the PTO or the tractors remote hydraulics I would put its own power on it. You burn through a lot of fuel and put a lot of wear on the tractor running it at constant speed for several hours. Now with that said if you happen to have one of these new fancy tractors they don't mind as much or if you have a 1000 rpm pto and can run the tractor slow to make it work you might consider it.  OH and as far as osha is concerned it only protects people working for you. So if you don't pay anyone who helps you build whatever you want. >:D
SE Mass
« Reply #10 on: March 27, 2017, 05:00:21 PM »
I think you have seen my operation haven't you Al, if you haven't you should!
« Reply #11 on: March 27, 2017, 05:13:39 PM »
I emailed the guy about it and he said he would recommend removing the 6 way wedges. That is the only reason I was looking at it to start with.
I will just stay with the Speeco for now.
« Reply #12 on: March 27, 2017, 09:28:42 PM »
No not really, I’m sure an OSHA inspector would shut my firewood processor down immediately if they seen it. Most other things around the farm we make sure is shielded well from having extra help during harvest and everybody is reminded constantly that anything at anytime can self start on the drying setup and even with the signs saying so I’m sure an inspector could find fault wit something sooner or later since the common denominator anymore is a nanny state that doesn’t think it’s citizens should have to take any responsibility for anything.
