Author Topic: Second zone  (Read 7012 times)
patvetzal
  • OWF Model: ML36
Second zone
« on: March 26, 2017, 03:43:32 PM »
So everything is working the way we hoped except that the basement is a little cold. Decided to install another heat exchanger (read truck radiator) down there with a fan on it. After 24 hours the upstairs was 80 degrees, basement even hotter, floors all toasty etc. Realized that I gotta control that fan so I ran a pair of 110volt wires up to the kitchen and bought a Honeywell digital line voltage t'stat. As luck would have it, the kid gave me one for baseboard heaters, the one with the triac that cycles the fan every 10-20 seconds when the temp is close to the set point.
Currently I have an old dial type baseboard t'sat in place but we would like one with a little more precision and a readable dial. Don't need multi stage or programable.
Any suggestions of a model number for a line voltage, digital stat? That new truck radiator will then be the main heat source for the main floor as the heat distribution is better than the rad in the furnace duct....
Re: Second zone
« Reply #1 on: March 26, 2017, 07:17:28 PM »
A lux 100 thermostat should work. Or you could use a switching relay and then any normal wall thermostat.
Re: Second zone
« Reply #2 on: March 27, 2017, 10:19:53 AM »
Like RSI said, I'd use a cheap transformer, regular 24v.AC wall stat, and 90-370 SPDT relay. Simple and cheap.
