Author Topic: GX10, how is it after a few years?  (Read 27689 times)
dave_dj1
« on: April 04, 2017, 09:18:48 AM »
I have a chance to pick up a slightly used Hawkin Energy GX10 for short money. The guy says it was only used one season. The outside including chimney cap look brand new. He had trouble running it and didn't keep the tubes and cat clean and nothing but trouble with it so he never used it again. For the most part it looks new.
I have read good reviews about the GX10 but they are all older so I am looking for some updated information, who is using one and how do you like it.
Thanks,
Dave
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
  • Southeast Michigan
Re: GX10, how is it after a few years?
« Reply #1 on: April 04, 2017, 06:33:44 PM »
Just what is "short money"?   I only ask because NEW GX and HE stoves are showing up on Craigslist now a month after the Hawken auction.
Unless the guy is just about giving it away I would pass on it and look at the NEW HE's on CL.
I'm thinking the GX10 is also a small stove.
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Stihl 036pro, 362c, 064
Husk 385,570
Shindiawa 416
Griffin 14' Dump
dave_dj1
« Reply #2 on: April 10, 2017, 05:25:25 AM »
Thanks Roscoe, short money is $500 bucks. I have a small house, only about 900 sf with finished basement so say 1800, good windows and decent insulation.
I have been heating it with my homebrewed hot air outside stove, it works great but it's close to the house. I was hoping to get the GX10 and move it away from the house (a little piece of mind). It is a gasser too.
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
« Reply #3 on: April 10, 2017, 08:28:07 PM »
For $500 I don't think you could go wrong...............
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Husk 385,570
Shindiawa 416
Griffin 14' Dump
« Reply #4 on: April 11, 2017, 05:05:08 AM »
I would ask a lot of questions as to why it wasn't working for him. Hopefully it was user error.
But for $500 you could sell it for scrap and almost come out ahead.
If you need help making it run let us know. There are several guys on here with a fair amount of experience tinkering with downdrafters.
« Reply #5 on: April 11, 2017, 05:18:20 AM »
I don't think that the Hawken is a downdrafter, it says that it's afterburner technology, that says to me that it uses some sort of catalyst.
« Reply #6 on: April 11, 2017, 07:48:03 AM »
« Reply #7 on: April 11, 2017, 07:59:34 AM »
Thanks RSI, I guess I got schooled again! I wonder why they didn't bill it as a gasser and why it didn't succeed for them? I have never seen one up here!
« Reply #8 on: April 11, 2017, 12:08:00 PM »
I think it down drafted, then ran through a cat. It had horizontal tubes that required manual brushing. Probably not a bad machine but could have used some updating.
dave_dj1
« Reply #9 on: April 11, 2017, 05:07:08 PM »
Thanks everyone, I dragged it home today. Luckily there is a farm right across the street and the guy had a big old payloader and loaded it right on my dump trailer. One day soon I'll clean it up. The tubes are black and cruddy, the guy I bought it from is a scrapper and never used it, he's had it sitting there for almost 2 years and now he'w moving south so needs cash.
The story is the guy that bought it new didn't learn how to run it and had nothing but trouble with it so after one year he stopped using it. It looks about like that happened.
It does have the cat, any ideas on cleaning it or wait until I fire it up and let it clean itself?
I watched one video and they used a cable with a frayed end to clean the tubes along with the vacuum.
Looking forward to experimenting with it. I keep a few years ahead on wood so dry wood shouldn't be a problem.
I will most likely take you up on the offer of lending some advice and tech when the time comes. I figure I have all summer to get the pipe, get a circulator and a HX for in my furnace plennum. I do have a question about heating my domestic, should that be first in line or last in line? The furnace and elec water heater are right next to each other.
Thinking maybe a modine type heater in the garage and use the second set of lines for that? The garage is only about 20 x 22 sort of insulated.
Thanks all,
Dave
« Reply #10 on: April 11, 2017, 05:56:20 PM »
We always do a flat plate first for dhw, then a bypass valve (if you want to run in summer), then hot air hx. That way the air handler can't mess with water temps while you're in the shower. :)
« Reply #11 on: April 11, 2017, 05:59:29 PM »
Garage could come off another furnace outlet or a secondary loop pumped off of two tees after the house air handler. Do whatever uses less pipe.
« Reply #12 on: April 11, 2017, 06:48:36 PM »
If the cat works anything like they did on the Nature's Comfort GT220 then you will want to just take out and throw away. Didn't really do anything but plug up.
dave_dj1
« Reply #13 on: April 13, 2017, 05:56:47 PM »
I guess only time will tell. I got the thing home, it's sitting in my yard in my dump trailer. It's a lot heavier than I thought it was going to be. I'm not really sure what to do with it. I haven't decided on a spot for it yet...lol
I'll keep you all posted later on once I get it installed and running.
I do have a quick question regarding installation.
I have hot air heat in my house, no big deal I know. If I come in to the basement wall at the opposite end of the house from where the furnace is will I be OK to run non insulated pex the length of the house (40') walk out ranch with finished basement (dropped ceiling). I guess I could always use some pipe insulation on it. The reason for this is because my garage is on that end and I would use less underground pipe this way.
thanks
dave_dj1
