Author Topic: Can you run a pump vertically?  (Read 6225 times)
Mr. Maple
  • OWF Brand: Empyre 450-sold,P&M BL 4044- sold,now Heatmaster
  • OWF Model: MF 20000e
« on: April 15, 2017, 06:14:15 PM »
  Our Grundfos pump is mounted horizontally,that is east to west,as is my Fathers Taco pump. I have a possible usage for another pump next spring,the hot distillate water coming from my maple syrup evaporator to be pumped back into the pans to clean them periodically.If the pump were mounted vertically,north and south would it drain back completely that I wouldn't have to worry about freezing up?
Thanks in advance for your help
Re: Can you run a pump vertically?
« Reply #1 on: April 15, 2017, 06:42:56 PM »
As long as the shaft is horizontal it doesn't matter.
« Reply #2 on: April 16, 2017, 01:26:34 AM »
Depending on the model, you may need to remove the check valve.
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« Reply #3 on: April 16, 2017, 09:14:50 PM »
Keep in mind where the pump will be located.  If the water level is higher than the pump than like RSI said it can be mounted vertically.  My stove has a 90 degree elbow and the pump pushes water straight up through my loop then back into the ground to my house.
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
« Reply #4 on: April 16, 2017, 10:09:58 PM »
Mr. Maple
« Reply #5 on: April 17, 2017, 10:12:20 AM »
The water pump would be higher than the tank of water,so it would probably be drawing the water up about 4',then pumping it up a further 4' into the pan
« Reply #6 on: April 17, 2017, 10:47:50 AM »
I’m not sure a normal circulation pump will pull water up 4’.
I know on our transfer pumps we have to add water thru a fill hole to get em to prime if the liquid is much below the inlet of the pump, pretty much same design pump.
« Reply #7 on: April 19, 2017, 11:05:44 AM »
It won't work. You will need some sort of self priming pump.
Even if you were able to fill the pipes with water then turn it on, it might work for a while but probably not last very long.
Smokeless
  • OWF Brand: HeatMaster ss.
  • OWF Model: G-100, 200,400
    • PCWoodBoilerSystems
« Reply #8 on: May 02, 2017, 04:01:52 PM »
Won't work for long. The back bushing will never get cool by the water or sap. It will Entrap air and wear out quick. or make noise.
Signature:
JD 401-c /Honda300atv/CAT 922-B/twofarmallCubs/2135 diesel Massey/8 chain saws/JMSloader/ 2017 Chevy Duramax 2500 HD
HeatMaster/Logstor  dealer for North east area NY VT NH MASS. Sales, installations, troubleshooting of hydronic systems and gasification issues.  Saratoga co, NY
