Pages: 1 ... 4 5 [6] 7 8
Author Topic: Pour over  (Read 43475 times)
coolidge
Re: Pour over
« Reply #75 on: April 29, 2017, 04:37:17 AM »
They are marked
Had 1300 ft of pipe, there is 1250 there, I have a six loop manifold, I could tighten the middle up and add a short loop.
« Last Edit: April 29, 2017, 04:43:17 AM by coolidge »
Western Maine
Re: Pour over
« Reply #76 on: April 29, 2017, 05:23:17 AM »
I would agree with you guys about the distance between line but since it is in a garage and no one is walking on it with bare feet I don't think anyone will notice. On another note check out the program LoopCAD. It has a 30 day full program trial. Awesome program!
Re: Pour over
« Reply #77 on: April 29, 2017, 05:29:58 AM »
I would agree and being that is closer to the center it should be fine.
Re: Pour over
« Reply #78 on: April 29, 2017, 08:34:41 AM »
So did you find a leak?
coolidge
Re: Pour over
« Reply #79 on: April 29, 2017, 10:34:19 AM »
Haven't looked yet.
Western Maine
Re: Pour over
« Reply #80 on: April 29, 2017, 10:41:01 AM »
Interesting, by looking at the insulation on the walls your vapor barrier is sprayed on ?
coolidge
Re: Pour over
« Reply #81 on: April 29, 2017, 01:10:49 PM »
thats 2" of closed cell foam sprayed too the original concrete. I don't know why i put that insulation on the walls, there is insulation on the outside already.
Western Maine
Re: Pour over
« Reply #82 on: April 29, 2017, 01:26:12 PM »
Better to ponder why you did it than wishing you did it.
coolidge
Re: Pour over
« Reply #83 on: April 29, 2017, 02:00:39 PM »
My plan is to strap that Insulation and put up some plywood, on walls that don't have shelving or benches anyway.
Western Maine
schoppy
  • OWF Model: G200
Re: Pour over
« Reply #84 on: April 30, 2017, 09:36:32 PM »
Did you leave a spot for the supply/return from your OWB to come through the floor, or any other penetrations you need?
Is your garage a pressurized closed system separate from the OWB system? If it isn't, how are you tempering the water from the OWB?
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
coolidge
Re: Pour over
« Reply #85 on: May 01, 2017, 03:17:54 AM »
I am leaving the OWB lines where they are( orange pipe).
Running an open system from boiler, there is a mixing valve down in that mess somewhere.
Would it be beneficial to pressurize the system?
Western Maine
Re: Pour over
« Reply #86 on: May 01, 2017, 09:48:07 AM »
I've never pressurized a floor, just mixed and dumped the furnace water right into the floor loops. Used mixing valve or injection mixed on a big slab.
« Last Edit: May 01, 2017, 10:07:27 AM by E Yoder »
Re: Pour over
« Reply #87 on: May 01, 2017, 12:34:11 PM »
Seems like it would be hard to balance flow , keep a loop from getting air bound and also what do you do if you want to stop heating te floor in the cold months as far as freezing goes?
Re: Pour over
« Reply #88 on: May 01, 2017, 12:37:52 PM »
If you want to run glycol then just need a plate exchanger, my snow melt isn’t pressurized and works just fine.
Re: Pour over
« Reply #89 on: May 01, 2017, 02:55:32 PM »
I have mentioned before and I'll do it again Honda, Eldon is in Va, he can get away with a lot of stuff down there that folks up here would nail your private parts to a stump and push you over backwards for doing.
