Author Topic: Oil vs propane  (Read 6654 times)
Oil vs propane
« on: May 23, 2017, 03:56:27 AM »
So I am thinking I am going to have one of the above installed and maybe only burn wood for a few months instead of the 8 I am burning now. I would have a unit big enough to heat the shop also and keep the OWF hot via the Logstor.
Now propane doesn't have the btu output of oil, but would think an easier install?
I would buy my own tank.
Thoughts?
Re: Oil vs propane
« Reply #1 on: May 23, 2017, 05:24:37 AM »
Buying your own tank is definitely the way to go, we owned two 1000 gallon tanks when we still had LP, pretty huge savings can be had when you can shop around, but we could burn thru several thousand gallons in no time when drying corn.
A second heat source is definitely desirable, I use waste oil in the shop for back up heat, if it’s a fluke temp swing I also have a nat gas furnace in the basement. I still end up burning wood 5 or 6 months out of the year.
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
Re: Oil vs propane
« Reply #2 on: May 25, 2017, 07:33:22 PM »
Buy your own tank, no questions asked.  You can then shop around for the better priced propane instead of having to stay with a company or even a contract.  Propane prices can ranged for 20-30 cents a gallon difference around here from company to company depending on their supply and demand.
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
Re: Oil vs propane
« Reply #3 on: May 28, 2017, 02:50:31 PM »
Propane don't go bad as quick either.
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
