Author Topic: Comments suggestions?  (Read 7686 times)
donahuej
  • OWF Brand: American Royal
  • OWF Model: 7300
« on: April 02, 2011, 06:20:23 AM »
I'm getting ready to pull the trigger on the material list.  Please take a look and shoot holes in this layout  :bash:.....I know the pump is at the stove...what do you think?  Good bad?
Thanks for the help,
Jamie
R W Ohio
Re: Comments suggestions?
« Reply #1 on: April 02, 2011, 10:01:55 AM »
I don't see how the mixing valve will work the way you show it.
R W Ohio
Canal Fulton,Oh.
donahuej
  • OWF Model: 7300
« Reply #2 on: April 02, 2011, 12:17:20 PM »
Your right - i need to catch a cold supply... :bash: :bag:
« Reply #3 on: April 02, 2011, 01:29:31 PM »
The ball valves at the water to air heat exchanger need to be on the heat exchanger side of the tees.
Are you planning on heating the water on the way out of the water heater tank or going in? It looks like you have it setup so on the way out and not heating the tank but you would need a valve to keep it from completely bypassing the plate heat exchanger.
donahuej
  • OWF Model: 7300
« Reply #4 on: April 02, 2011, 01:33:45 PM »
I think I want to heat the water after the tank - that's my intention ulness you guys think differently?  I'  add a check valve good one.
Thanks
