Author Topic: New Rules for 2020  (Read 25472 times)
Re: New Rules for 2020
« Reply #1 on: August 15, 2017, 11:50:44 PM »
Long as they don’t decide to tighten em up even more before 2020, several manufacturers already have stoves that pass the 2020, regs. The G100 and G200 from Heatmaster already pass as well as the smaller two from Polar.
« Reply #2 on: August 16, 2017, 03:03:02 AM »
As was mentioned in the article, cost of testing is a big killer. The timeframe is tight enough but maybe doable.... But the cost at the same time slows innovation. It's a tough situation.
It sounds like the warm air furnace manufacturers are in a tougher spot than the OWB manufacturers.
« Last Edit: August 16, 2017, 03:12:40 AM by E Yoder »
« Reply #3 on: August 16, 2017, 07:06:25 AM »
I didn’t delve into the whole article too deep, but will coal boilers still be allowed for residential use after 2020?
We went to a Steam and Power show over the weekend, you could tell which ones were burning coal by the god awful stench if you got downwind of em, made a diesel rolling coal seem like perfume. I mean these things smelled like they were burning used jockstraps, didn’t matter is they were just sitting or running, they stunk.
Roger2561
« Reply #4 on: August 16, 2017, 01:49:50 PM »
Growing up (er, I mean getting older) we had a coal fired boiler in the basement of our old farmhouse.  I can remember smelling the coal gases if something wasn't running just right.  Man, did that ever stink.  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
« Reply #5 on: August 16, 2017, 02:25:12 PM »
I don't think the coal exemption is supposed to change but it's been a while since I read all the way through the NSPS. I'm not sure I feel like wading through it again soon either. :o A lot to absorb..
 I think the allowed emissions drop on wood units and the way they average test runs is more stringent.
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« Reply #6 on: August 24, 2017, 12:27:06 AM »
I thought I read something saying coal was good until 2025 and from then a clean burn act was in process.  This would be for power plants as well.  Called clean coal or something like that. Would need to have an electronic device in the chimney to catch all fine ash particulate plus a reburner filter and catalytic converter
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
duramax
  • OWF Brand: central boiler
  • OWF Model: 1450
« Reply #7 on: November 11, 2017, 08:01:31 AM »
With Trump in office I don't worry about it. Wood stoves and boilers are safe for now.  When I  went to buy  an OWB  3 years ago I had to buy a gasifacation boiler  due to laws in the Peoples republic of Massachusetts, at first the cost pissed me off but it runs great and I burn allot  less than another wood boiler guy I worked with.
I still have my old coal stove in the basement as back up. It burns anthracite so it has no smoke. Still run it here and there in the winter. Nothing beats the heat a coal fire on a cold snowy day.
Central Boiler E 1450 Homemade 13 hp wood splitter, Kubota L 3800 tractor
« Reply #8 on: November 11, 2017, 05:14:01 PM »
Really after burning downdraft for over three years I'd never go back to a conventional,  law or no law. They work so much better and more efficient.
fireboss
  • OWF Model: 6048
« Reply #9 on: November 11, 2017, 05:26:30 PM »
Noing what you know now,would you have switched for  no reason ? There’s nothing wrong with my furnace, and i never paid for wood yet . But thinking 🤔
« Reply #10 on: November 11, 2017, 05:28:02 PM »
Actually when I replaced mine I still had a year left to get a conventional. Less wood for starters and no billowing clouds of smoke for another.
« Reply #11 on: November 11, 2017, 05:36:52 PM »
Same for me. Less ash too .
« Reply #12 on: November 11, 2017, 05:44:16 PM »
Nobody knows you're even burning wood unless they see you hauling it in. I've seen G's running in pretty densely populated areas with no complaints.
Pointblank
« Reply #13 on: November 12, 2017, 05:25:57 AM »
Same here, I could have gone with another conventional when I purchased my current stove. Burning at least 1\3 less wood and no more smoke sold me on a gasifier.
Minnesota
NaturallyAspirated
  • OWF Model: M250
  • Golfing, snowmobiling fool!
    • http://www.nealmastel.com
« Reply #14 on: November 30, 2017, 06:52:08 PM »
So it seems the hated liberals pushing the law wasn't so horrible after all....   >:D
