Author Topic: Flex hose for pump hook up at boiler  (Read 7351 times)
tinfoilhat2020
  • OWF Brand: POS
« on: September 18, 2017, 07:31:44 AM »
Hey guys got the heatmaster G 200 set in Place this weekend I ran 1.25 inch Reauh insulated PEX....man that stuff was a BITCH!!!!!!! With the help of my son in about 5 ratchet straps he finally got it placed into the boiler with about 2 ft to spare extra inside the back rear panel. My dealer suggested probably using a 1.25 inch flexible heater hose to make the pump connections as that stuff is going to be hard to straightened out and get in place. I know there were some threads from last year were some others had used this method. Anyone have pics???
i prefer to run all copper if i can....any other ideas for molding the pipe to you can work with it a bit?
thanks gents
Re: Flex hose for pump hook up at boiler
« Reply #1 on: September 18, 2017, 08:28:46 AM »
I used 1 inch rubber truck heater hose. It is rated for these temps and allows for expansion and contraction of the pex as it heats up and cools down.
« Reply #2 on: September 18, 2017, 12:48:19 PM »
Use a heat gun or hair dryer to heat the stuff up, it moves a LOT easier if warm. 1” heater hose will work, you have 1” ports on the stove anyways.
Jon_E
  • OWF Brand: Heatmaster SS
  • OWF Model: G200 Gasifier
« Reply #3 on: September 18, 2017, 12:57:12 PM »
Another vote for the rubber heater hose.  Mine was supposed to be temporary but no reason not to keep it permanently.
tinfoilhat2020
  • OWF Brand: POS
« Reply #4 on: September 19, 2017, 06:25:54 AM »
thanks guys...gonna try the heat gun method first!!!
« Reply #5 on: September 19, 2017, 05:09:54 PM »
A little heat does wonders.
Enjoy your new  G. I think you'll like it a lot.
schoppy
« Reply #6 on: September 19, 2017, 09:19:36 PM »
I used a heat gun to help with my 1 1/4" and it worked pretty good. Just remember to heat evenly all the way around the pipe and over 9 to 12 inches in length depending on how much you need to bend it. Be careful to keep the heat gun moving and not over heat any one spot.
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
« Reply #7 on: September 19, 2017, 09:56:51 PM »
Probably a little late now, but bring it in one hole of the stove then connect to the other side and vice versa with the other one. This will also give it some flex if something settles.
