Author Topic: Low Water  (Read 5709 times)
hoardac
  • OWF Brand: Heatmaster G-200
Low Water
« on: September 29, 2017, 08:21:41 PM »
Where is the low water switch located on the g200 have a low water alarm need to check it out.The instruction manual is pretty damn vague on location and it is dark out. Glad this was just a trail run. It got up to about 175 then water sensor quit I guess. Topped it of just to make sure but that was not it. The cover had a screw spin the insert glad it was warm out cause i probably would have broke the plastic frigging around with it. I did not have voltage so I need to check for continuity. Thanks for any help, tips or tricks
Re: Low Water
« Reply #1 on: September 29, 2017, 08:33:18 PM »
The float switch is beside the control on the last couple year models I think . Take out the 4 screws, should see a plastic piece threaded in with two wires.
I had one stick and I tapped on the tank beside it and it started working.
Re: Low Water
« Reply #2 on: September 30, 2017, 01:43:35 AM »
How old is your unit?
hoardac
Re: Low Water
« Reply #3 on: September 30, 2017, 11:47:12 AM »
I bought the unit the very end of last year Dec 31. I kept the unit on to take what heat was in it inside and when I woke up it was working fine. Must have been stuck.
Re: Low Water
« Reply #4 on: September 30, 2017, 02:31:16 PM »
Good to hear.
