Author Topic: bl34-44 supply line?????  (Read 17906 times)
GUSWHIT
« on: November 13, 2017, 08:35:02 AM »
Finally finishing my hook up.  I misplaced my directions so I have been searching on line and downloaded the instruction manual for my stove.  The question I have is the instruction PDF shows the supply line coming off the top of the stove and I saw a couple of other posts that indicated that this was incorrect and the supply was supposed to come off the bottom nipples?  What have the rest of you done?  What really is correct?
Re: bl34-44 supply line?????
« Reply #1 on: November 13, 2017, 10:08:15 AM »
If I remember correctly, they had boiling issues or poor mixing of the water pulling off the top, pull off the bottom and it those issues won’t arise.
GUSWHIT
« Reply #2 on: November 13, 2017, 12:56:50 PM »
I thought I had read that, and that Slim had chimmed in once about hooking the supply up to the bottom, but the directions I printed off still indicate to pull from the top. I'm stuck right now, may have to call unless a member chims in on how they did  their install.
agriffinjd
  • OWF Model: BL 3444
« Reply #3 on: November 13, 2017, 01:36:09 PM »
My P&M dealer said to ignore the instructions: pull from the bottom of the stove.  It helps with the mixing, but also avoids sucking air in case you run low on water for any reason (leak, boil over, etc).  So that's how my 3444 is setup.
U.P. of Michigan
GUSWHIT
« Reply #4 on: November 13, 2017, 02:39:06 PM »
How long have you been operating your stove?  No noticeable issues?
« Reply #5 on: November 13, 2017, 05:05:51 PM »
Pull from the bottom!
wreckit87
« Reply #6 on: November 13, 2017, 07:37:09 PM »
I do have a customer with a 28-40 that's been pulling from the top for 7 years and has had no issues, but he also has a big load on it. I installed a new 28-40 a few weeks ago and pulled from the bottom, per the advice I received here and that's also performing well so far. The 28-40 at least, the manual on their site shows pulling from the bottom also. It's kind of a bugger to get the pump in there, but it fits
« Reply #7 on: November 13, 2017, 07:44:37 PM »
Yah, I just hooked up a Woodmaster 434 for somebody, they pulled from the bottom, or at least the original owner did, that lower port is a bugger cause the pump is so low. Also it was old enough I wasn’t about to get the big pipe wrench out to change anything.
wreckit87
« Reply #8 on: November 14, 2017, 08:18:04 AM »
That leaker I posted on FB the other day was a 434 also. Darn things sit so low anyway, we set it on top of concrete hog slats and then treated 6x6 posts under the legs also so it's a foot higher than if it were on ground level. Door height is perfect, AND there was room to get the pump underneath without it lying in the mud. Pretty precariously perched, but it works nicely so far. Per the Woodmaster 4400 manual, they wanted to pull from the bottom also so that's what I did. This particular unit had gate valves side by side down below so the connection points were both the same height anyway. Believe it or not, the gate valves even held water!
GUSWHIT
« Reply #9 on: November 15, 2017, 10:51:18 AM »
I sent a message to Portage & Main and they just got back to me with copies of the manual and a short note explaining that the pump should go to the bottom ports for the supply and the top ports for the return.  So my next step was to look at the PDF manuals he sent and guess what?  Yep, that manual on page #12 shows the supply ports on the top.  WTF!  I'm putting them on the bottom, that makes the most sense to me.
« Reply #10 on: November 15, 2017, 12:06:10 PM »
Probably got missed updating.
Most are pulling from down low now.
Super44
  • OWF Model: Ultimizer BL 2840
« Reply #11 on: November 15, 2017, 09:02:25 PM »
I have been pulling from the bottom for 3 seasons now with my BL28-40 with no issues.
GUSWHIT
« Reply #12 on: November 16, 2017, 12:24:38 PM »
Got the last few parts last night, hopefully by the weekend I will have it circulating with the boiler treatment in it.  If I can get a few hours away from the kids to get it the rest of the way plumbed.
tinfoilhat2020
  • OWF Brand: POS
« Reply #13 on: November 16, 2017, 06:17:22 PM »
i totally understand that. still trying to work out a few kinks overt here and everything has to wait until the weekend...kids sick up my entire week... lol
wreckit87
« Reply #14 on: November 17, 2017, 07:13:57 AM »
I don't even have kids and this stuff tends to get put off forever lol
