Author Topic: Just not draughting right or something  (Read 16027 times)
Bluegrass Wood Burner
  • OWF Brand: Ozzark Biomass
  • OWF Model: Gasconade 500 gallon
« on: November 15, 2017, 03:06:33 PM »
Folks I'm having all it'll trouble with my boiler just not blazing up right. It takes forever to get it from 170 to 180 and it just isn't blazing up. I open the door and it's a low flame and the longer the door is open the more it blazes up. Shouldn't it be blazing more with door closed and blower on than blower off and door open. My wood is hardwoods oak hickory and locust that have been cut couple years. Most is dry with some getting wet when it rains. I checked the flu stack and it's clear. I always thought if blower goes out it just quits. Could it be getting weak?
South central Kentucky
Ford F-150
16 ft tandem trailer
3000# winch
Husqvarna 142
Husqvarna 460 rancher
6ft spud bar
Poulan 3314
22 ton lowes splitter
Timberline sharpener
"Worn out body"
Re: Just not draughting right or something
« Reply #1 on: November 15, 2017, 03:32:39 PM »
I would quicker guess that it's not getting good air flow from creosote buildup someplace blocking the flow, perhaps the fins on your blower?
« Reply #2 on: November 15, 2017, 04:05:57 PM »
I never thought of that. So should I take them off and soak in my acetone and ATF mixture? That would cut that creosote  I'm sure.
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
« Reply #3 on: November 15, 2017, 04:15:56 PM »
If they are clogged then They definatey should be cleaned
« Reply #4 on: November 15, 2017, 04:40:02 PM »
I took a small wire brush and brushed each fin and I didn't see any creosote to amount to anything. You are talking about the little squirrel cage fan on the comustion blower on the door?
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
shepherd boy
  • OWF Model: C375
« Reply #5 on: November 15, 2017, 04:53:49 PM »
 I think your stove is somewhat of a copy of a Taylor. They had a flap in the door that was supposed to swing open when the fan came on. Is that the way yours is?
Let the youngin's have it
 Gettin' old and lazy
« Reply #6 on: November 15, 2017, 04:59:39 PM »
Yes it is
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
shepherd boy
  • OWF Model: C375
« Reply #7 on: November 15, 2017, 05:04:12 PM »
 Taylor was bad about the flap sticking open or shut from ash or creosote in there. may want to check that.
juddspaintballs
« Reply #8 on: November 15, 2017, 05:44:04 PM »
The flap on my Heatmor got creosote on it and stuck open one year, causing a boil over.  I cleaned it up, oiled the hinge area, and keep it clean religiously now.  If mine could stick open, yours could stick closed.  I'd put my money on either a blocked air passage or stuck closed flapper.  Any mice build a nest in the space between the blower and the fire box?
« Reply #9 on: November 15, 2017, 08:02:53 PM »
I'm gonna check some of these things tomorrow. Flap door not sticking, I put the acetone ATF mixture on it and it keeps it free from sticking. I'm wandering if I just got some wet wood. The blower seems a little weak to me.
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
« Reply #10 on: November 15, 2017, 08:28:42 PM »
What's your opinions of the spark arrestor in back of firebox before smoke goes through the exhaust chamber and up the stack? I wander if that blocks the draft quite a bit. Would that many sparks go out stack of that wasn't on?
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
« Reply #11 on: November 16, 2017, 05:39:43 AM »
There's a round cover on outside of fan that you can turn to let more air in, however with the cover over the whole assembly it will only open about half or less.  If I took that all the way off it wouldn't hurt anything would it? That would give me extra air flow. I tool my air hose and blew out all that combustion fan housing and the channel going to the fire box and it seem to be clear.
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
tinfoilhat2020
  • OWF Brand: POS
« Reply #12 on: November 16, 2017, 05:58:06 AM »
depending on the size of the firebox and BTU desired I would definitely run the blower wide open, especially if burning wet wood.
« Reply #13 on: November 16, 2017, 06:02:33 AM »
I will take that cover off. I guess I could put it back on in summer to keep critters out. My wood is a little wet. I had a little to start off with that was not covered and been out in the rain. I should be out of it by the weekend and then seasoned red oak that has been covered.
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
« Reply #14 on: November 16, 2017, 07:52:23 PM »
I believe that solved my problem. Thanks everyone!
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
