Pages: 1 [2]
Author Topic: Extended Burn Times With Super Dry Wood  (Read 21952 times)
wreckit87
  • OWF Model: C375
Re: Extended Burn Times With Super Dry Wood
« Reply #15 on: February 09, 2018, 10:04:52 AM »
I hear a lot about stack temps , how do you monitor that , I have a bl28-40 with 3 sections of insulated pipe,
I picked up a BBQ thermometer from Mills Fleet for $12 with a 4" probe. Drilled a hole at the bottom of the stack pipe and inserted the thermometer
jreimer
  • OWF Model: Optimizer 250
« Reply #16 on: February 09, 2018, 12:06:27 PM »
This is a picture of the candy thermometer I installed.  Drilled a hole in the stack and inserted the probe end.
Shindaiwa 488
GMC Duramax 2500HD
Homemade splitter
Kubota B7500 w/loader
An understanding wife
heat550
  • OWF Brand: Heatmor
« Reply #17 on: February 09, 2018, 12:27:04 PM »
Right now I just keep rain cap from glowing but I need to get a sensor on it . I'm thinking temp gauge on the back clean out plate would tell me enough for adjustment. I'm going to try oven temp gauge sitting on back clean out plate.  :thumbup:
Heat550
heat550
« Reply #18 on: February 19, 2018, 11:27:49 PM »
Just to add . I tested some wet oak blocks in stove leaving it set to slabs drafting they don't burn they smolder. But they work good to keep a coal to start the slabs .. the drafting does work perfect . Set draft to moiture in wood . Just like old indoor stoves.. but saves you alot of wood that's for sure..
« Last Edit: February 19, 2018, 11:30:27 PM by heat550 »
patvetzal
  • OWF Model: ML36
« Reply #19 on: March 03, 2018, 04:11:45 PM »
Old wood that has started to decompose has already lost some of its energy/calories/BTUs etc but until that point, the drier the better for me.....While "fresh" damp wood might burn longer, all it is doing is boiling off internal moisture...
80 acres of Bancroft bush and Ontario rock, a sweet wife, a few chickens, fishing rod, most everything I need....Most of it made by John Deere, Polaris, Stihl, Ruger, Jeep or me...
heat550
« Reply #20 on: March 14, 2018, 01:09:32 AM »
Getting more tech in to the dry wood burning . Trick is backing off the drafts . Moiture meter took the mystery out of it . Now I want a remote temp sensor on chimney . And yes a Heatmor 400 can burn dry slabs . Takes chimney Cap and pans blocking off draft fans. Heatmor 400 1/3 full of dry oak slabs gets you 8 hours at -21f
Heating 6600sqft .. slabs burn super hot. 42,000 lbs of slabs for season central MN. That was my 2018 experiment.
Heat550
Heatmor 400 A.K.A Huge gasifier.
Picture of stove the draft fans are off. Can't have them on with door open . Cherry red rain cap is if you have pans on draft fans open to far.
« Last Edit: March 14, 2018, 01:29:19 AM by heat550 »
tinfoilhat2020
  • OWF Brand: POS
« Reply #21 on: March 14, 2018, 06:26:31 AM »
thanks for sharing! I miss my 400!!! I only got to play with it for 2 winters before we moved!!
heat550
« Reply #22 on: March 16, 2018, 12:33:36 AM »
Heatmors have there place the old style there as versatile as the operator wants them to be. This is why I got hooked in to them.
I have no clue why my 2015 400 didn't come with draft covers.
I put marks where to set draft chokes for what ever moiture wood I'm burning . It saves alot of wood . And range is 40% to 10% it's ruffly 1/8 increments. If I would burn wet wood in a pinch. Remove rain cap and draft chokes. Maybe everyone knows this . But it's the reason Guys with heatmors like them . You can burn what ever wood you have ... Or dry wood and save the back. 👍😀
Heat550
tinfoilhat2020
  • OWF Brand: POS
« Reply #23 on: March 16, 2018, 07:31:29 AM »
yeap I agree!
heat550
« Reply #24 on: March 22, 2018, 10:59:24 PM »
Now I got some wood that 30-40 % oak I burning drafts wide open and rain cap off . Chunk wood takes alot of draft.
Heat550
« Reply #25 on: March 23, 2018, 05:22:36 AM »
Yup, makes a big difference.
Pages: 1 [2]
