Author Topic: Pump  (Read 11357 times)
wormmister
  • OWF Brand: Wood Doctor
  • OWF Model: WDGS-70
Pump
« on: June 12, 2018, 07:41:39 PM »
Is there any way to check a pump?
Grundfos 2699..new just installed it and I don't think it's working.
Where's the best place to buy a new pump.
« Last Edit: June 12, 2018, 07:44:17 PM by wormmister »
Re: Pump
« Reply #1 on: June 12, 2018, 10:04:46 PM »
Remove the silver screw from the end of the motor and see if the shaft is spinning. If it is spinning, there are a few different things you can do but would depend on how it is mounted and where in the system. Post a picture of it along with some of the surrounding piping.
Re: Pump
« Reply #2 on: June 13, 2018, 06:08:07 AM »
And if it's not turning check for voltage at the pump before replacing. I had a bad receptacle once that made contact about half the time. Drove me nuts.
wormmister
Re: Pump
« Reply #3 on: June 14, 2018, 12:36:55 PM »
I think I got it.
Drained my system and removed the pump, removed the the big screw and used a small screwdriver to try and turn the impeller but I could hardly move it.so I decided to take the pump apart, took out one of the bolts and heard a metatic pop, removed the rest of the screws and the impeller turns freely now, put it back together and all is good now.
Thanks .
Re: Pump
« Reply #4 on: June 14, 2018, 03:25:49 PM »
Well, that's a good ending  :thumbup:
wormmister
Re: Pump
« Reply #5 on: June 14, 2018, 07:46:00 PM »
Yes
But now I have a leak on my manifold on a valve that I soldered.
Have to drain my system again.
Re: Pump
« Reply #6 on: June 15, 2018, 08:09:38 AM »
Too bad..
I looked up your model of furnace. Sounds like an interesting model, how's it run for you?
patvetzal
  • OWF Model: ML36
Re: Pump
« Reply #7 on: July 16, 2018, 01:27:49 PM »
I thought God made isolating valves so we didn't have to drain the whole system.....
