Author Topic: Boiler Room Set-Up  (Read 20863 times)
tinfoilhat2020
  • OWF Brand: POS
Boiler Room Set-Up
« on: August 29, 2018, 02:18:16 PM »
hey guys,
attached are some pics of my new boiler room set-up. we are getting close to completion, been way to fricking hot to do much lately.
Re: Boiler Room Set-Up
« Reply #1 on: August 29, 2018, 04:24:45 PM »
Nice.
Yup, last week's cool nights had me itching for fall. It didn't last long enough. :)
tinfoilhat2020
  • OWF Brand: POS
« Reply #2 on: August 30, 2018, 04:53:38 AM »
heat has been terrible...the humidity even worse
« Reply #3 on: August 30, 2018, 05:01:10 AM »
I see you have an exhaust fan above the stove, I'm curious how it works. Oh well, cold weather will be here soon enough.
« Reply #4 on: August 30, 2018, 09:51:08 AM »
Looking good.
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #5 on: August 31, 2018, 05:34:00 AM »
Do these stoves have a smoke bypass?
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
tinfoilhat2020
  • OWF Brand: POS
« Reply #6 on: August 31, 2018, 03:50:15 PM »
No, they have a "load switch" which activates the fan motor for 120 seconds. I hit the load switch, crack the door and it clears the smoke pretty quick. Not quite as convenient as the smoke bypass (I had a g200 last season), but, one less area to have issues with as well. My smoke bypass was the reason my first G200 had to be replaced within the first 90 days on operation. The metal where the hole is cut for the bypass was bent and the bypass would not make a tight seal, which results in little to no gasification. I actually talked to my dealer the other day and after many attempts to try and fix it over the next year, he is finally just sending it back to the plant as there is nothing he can do with it.
bowhunter79
  • OWF Brand: Natured Comfort
  • OWF Model: 175
« Reply #7 on: January 21, 2019, 09:13:31 AM »
You have had a g200 and a crown pristine. These 2 are my top 2 choices for replacing my natures comfort.  I know the crown you have is bigger but how would you compare wood consumption between the 2 and the build quality?  Thanks.
tinfoilhat2020
  • OWF Brand: POS
« Reply #8 on: January 25, 2019, 01:22:53 PM »
wood consumption is very comparable. both are a solid unit and burn clean and efficient.
bowhunter79
  • OWF Model: 175
« Reply #9 on: January 28, 2019, 06:28:06 AM »
Thanks for the info.  I am hoping to take a look at both this summer and make a choice if I can sell my 5 year old NC175.
