Author Topic: E classic 1450 question  (Read 10011 times)
Hunt4heat
  • OWF Brand: Central boiler
  • OWF Model: 1450 edge classic
« on: December 05, 2018, 06:29:26 AM »
Hi all,
This is my second season using my central boiler 1450 and my question relates to the fire box clean out attached is a picture of the rear lower portion that has kind of a roof shape, that I'm wondering how to remove this to clean the build-up out of that area? It looks like the top portion is just fit into a channel but the bottom looks to be welded? This is where the are over fire originates from and is really difficult to clean without removing this portion, let me know what you guys have come up with in the past I have just been using a long spring that I push through and scrub it out the best I can thanks Matt
Re: E classic 1450 question
« Reply #1 on: December 06, 2018, 10:13:59 AM »
Hi Matt - The picture didn't show up on the forum.  I used to have a E-Classic 1400 which is the sister to the 1450 and I don't recall seeing a roof shaped area inside the fire box.  If you can, try posting the picture again, it may jar my memory.  Roger
smithbr
  • OWF Model: E-Classic 1450
« Reply #2 on: December 06, 2018, 07:26:25 PM »
There is a metal shed-shaped structure at the center back of my 1450.  That location is where the gas igniter would be, if I had purchased the option.  The shed structure lifts straight up and off the holder.  There's little point in fussing with it though, as there's nothing behind it.
Much more important to lift the four corner shields and clean out the creosote that accumulates in those air channels.
Blair
« Reply #3 on: December 07, 2018, 03:06:06 AM »
Blair - I now remember that piece.  I had removed it after my first year heating with the 1400.  It was simply in the way.  Roger
duramax
  • OWF Model: 1450
« Reply #4 on: December 10, 2018, 02:05:57 PM »
 I will admit that I had no idea what it was, I didn't need the gas ignition. What the heck are the 2 bars hanging on the sides of the fire box? I assumed that they are like sacrificial rods in a water heater?
« Reply #5 on: December 10, 2018, 05:32:03 PM »
duramax - Those bars are to prevent the firewood from resting against the air holes blocking the air from doing it's job.  Roger
smithbr
« Reply #6 on: December 10, 2018, 06:41:15 PM »
I think they're also a lame attempt to destabilize the wood so it doesn't arch as often.  If so, it was wasted effort.  I can pile it right, and not arch, or I can pile it wrong, and arch most of the time.  The 1450 may actually just be too narrow for the size of wood I prefer to split.  I'm having to split it smaller than i like to prevent it arching.
Just my two cents.
Blair
duramax
  • OWF Model: 1450
« Reply #7 on: December 13, 2018, 10:57:07 AM »
Good to know, I can now take them out so I can scrape the sides better. I just make a quick pass every other day with an ice chipper.
I split most of my wood for it smaller for two reasons, the first is it fires up quicker with smaller pieces and the best one of all is my wife helps keeping it going and she hates the weight of the larger pieces. I do have some bigger stuff for long cold nights and some of that is the twisted knot filled stuff not worth splitting.
