Author Topic: Stack temps  (Read 10053 times)
schoppy
Stack temps
« on: December 06, 2018, 09:59:37 PM »
Not sure if this question has been asked before but has anyone tested the stack temps on their gasser when running wide open? Is there any tech data that says what it should be? I have the G200.
I plan on testing mine tomorrow as it's supposed to be our coldest day so far this year.
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
tinfoilhat2020
  • OWF Brand: POS
Re: Stack temps
« Reply #1 on: December 07, 2018, 03:23:57 AM »
Last year I monitored them all year. Temps were generally in the 350-450 range, sometimes a bit higher.
jreimer
Re: Stack temps
« Reply #2 on: December 07, 2018, 08:57:15 AM »
Mine are in the 280 to 350 range, depending on how badly the tubes need cleaning.  Normally it's around 320 after a fresh load and around 250 once it's more coals.  I saw 370 once but that was an anomaly.
Shindaiwa 488
GMC Duramax 2500HD
Homemade splitter
Kubota B7500 w/loader
An understanding wife
Re: Stack temps
« Reply #3 on: December 08, 2018, 03:06:04 AM »
Schoppy, please post what you find. I'd like to play around with some of that stuff, but no time to do it.
schoppy
Re: Stack temps
« Reply #4 on: December 09, 2018, 09:25:59 PM »
I checked mine when I knew it was really gassing hard. I got 351 degrees (F) and my secondary burn chamber down under was glowing red. This was at the top of my stack which is 7 1/2 feet tall.
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
