Author Topic: Turn off blower  (Read 12936 times)
MD20/20
  • OWF Brand: Nature's Comfort
  • OWF Model: 325G
Turn off blower
« on: December 12, 2018, 09:56:11 AM »
What’s the latest and greatest way to turn off the blower motor on my 325G when water temperature drops belong a certain point. Sometimes I’m lazy and don’t get to the fire in time and I’d like the blower to not blow cold air into the firebox.
I have a ranco aquastat.
Thanks.
Central MD
smithbr
  • OWF Model: E-Classic 1450
Re: Turn off blower
« Reply #1 on: December 13, 2018, 06:03:26 AM »
Well, what you want is a temperature switch that opens at around 165, I guess.  (depends on your particular furnace parameters).  Place that so it senses the water temperature leaving the furnace (not your return water).  You may need a lower temperature, it will depend on how accurately you can sense the true water temperature.  If I had to do this, I might look for an adjustable switch, like the one on a hot water tank).  Wire it in series with the power to the blower.  Make sure you put in an override switch to keep it going when you want to restart the fire.
Of course, you really shouldn't run the water below 150-160, they say, due to increased condensation.  I'm guessing that if you're not burning anything, there isn't much water vapour around, but I could be wrong.
If I did this, going by my water temperature swings, the blower will run for more than half of that one hour period before it shuts off at 165.
Even though my furnace starts demand at 175, if all my heat loads are sucking at the same time, water temperature gets close to 170 before the fire takes over, so I couldn't cut out the fan much higher than 165.  So there's not a lot of savings to be had.  But your situation may be different.
There may be good reasons for not doing this, I'll think about it.
Re: Turn off blower
« Reply #2 on: December 14, 2018, 07:09:46 PM »
I still have a few of those Ranco controllers available that I had modified for that purpose. They are setup to wire in series with the existing controller.
There are cheaper ways to do it if you want to wire up stuff or use a timer.
MD20/20
  • OWF Model: 325G
Re: Turn off blower
« Reply #3 on: December 16, 2018, 02:34:19 PM »
I’d be interested in the best and most simplistic way to do it....
Central MD
