Author Topic: thermostat for infloor heat  (Read 32162 times)
sceptre74
  • OWF Model: BL 28-40
« on: March 05, 2019, 01:24:35 PM »
Is there different thermostats for different applications? I was told there is and if so, I'd like to know what is a good or the best one for infloor heat in a shop
kjw58
  • OWF Brand: Natures Comfort
Re: thermostat for infloor heat
« Reply #1 on: March 05, 2019, 02:08:53 PM »
The one I use is a AUBE, works great.  About $50
S.E. Mich.
New Holland TC40DA
IH 464 w/2250 Loader
6 x 10 Dump Trailer
2 Stihl 261's
Poulan 3400 & 3700
Poulan 2150
Homelite Super XL
sceptre74
« Reply #2 on: March 05, 2019, 02:32:05 PM »
Would you happen to know the model number?
« Reply #3 on: March 06, 2019, 04:29:11 AM »
I use a lot of Honeywell T1 Pros for various systems. Cheap and reliable.
sceptre74
« Reply #4 on: March 06, 2019, 06:11:19 AM »
I'm having issues with the shop being a huge draw on the system. It seems like there won't be a call for heat sometimes beyond 24 hours. Someone suggested finding a thermostat that will turn on closed to the set point so this is what I want to try.
kjw58
« Reply #5 on: March 06, 2019, 02:23:14 PM »
I don't know the model number of the AUBE thermostat that I have.  I was told that it was designed for hydronic floor heating, it has been in my shop now going on 14 years and works great.  When the room temp calls for heat, it turns the pump on and the pump runs for a short time and it will shut off and allow the water temp to recover and then turn back on automatically, it will continue to do this until it reaches the set point. there are 4-5 dip switches that you can setup to use it for different applications. If I recall correctly I got mine from Menards.  Hope this helps.
S.E. Mich.
New Holland TC40DA
6 x 10 Dump Trailer
2 Stihl 261's
Poulan 3400 & 3700
Poulan 2150
Homelite Super XL
sceptre74
kjw58
« Reply #7 on: March 07, 2019, 01:11:02 PM »
yes that looks like the one I have. :thumbup:
S.E. Mich.
New Holland TC40DA
6 x 10 Dump Trailer
2 Stihl 261's
Poulan 3400 & 3700
Poulan 2150
Homelite Super XL
sceptre74
« Reply #8 on: March 07, 2019, 01:49:40 PM »
Awesome. Thanks
Tim Guinn
  • OWF Brand: portage and main
  • OWF Model: bl 3444
« Reply #9 on: March 08, 2019, 05:59:05 PM »
I saw this thread and was wondering, since it cycles the pumps once every 24 hrs to prevent pump seizure, does it do this even in the summertime when there is no demand.  This would be great for me so I don't have to remember to cycle the pumps year round. Tim
sceptre74
« Reply #10 on: March 08, 2019, 07:00:01 PM »
From what I understand it will do it year round. I ordered one so I'll know soon enough!!!!
wreckit87
« Reply #11 on: March 12, 2019, 02:22:32 PM »
Your pump only runs every 24 hours because your supply water is too hot. A new thermostat is not going to fix that. Do you have a mixing valve in place? What is your water temp entering and exiting the slab?
sceptre74
« Reply #12 on: March 12, 2019, 04:28:31 PM »
Yes I do. It's coming in at 95 and leaving at around 77 78.
wreckit87
« Reply #13 on: March 12, 2019, 04:43:07 PM »
Must not be keeping it very warm in there? At that rate is roughly 5,000 BTU per hour per loop of radiant so unless this is a very large building it shouldn't be pulling so hard on the boiler to maintain temp.
sceptre74
« Reply #14 on: March 12, 2019, 05:30:11 PM »
I have it set at 60 and it's 32 x 44 with 10 foot walls I had the water coming in at 105 or so but dropped it and seems to be somewhat better.
