Author Topic: Ibc heater  (Read 10429 times)
ijon
  • OWF Brand: Portage and main
  • OWF Model: 28-40
Ibc heater
« on: June 29, 2019, 05:38:11 AM »
Anybody  got any ideas on how to make a heater to heat a ibc tank off your wood boiler. I am overwintering Tilapia in my garage for the winter. I could run the pex through the tank but the key would be to regulate the temp. Thanks in advance.
installed in 2014
Re: Ibc heater
« Reply #1 on: June 29, 2019, 05:49:07 AM »
A simple Aqua Stat probe in the tank to control a circ and an adjustable tempering valve should do the trick for you.
ijon
  • OWF Model: 28-40
Re: Ibc heater
« Reply #2 on: June 30, 2019, 05:31:36 AM »
Thank you my old friend. To the rescue as always.
installed in 2014
Re: Ibc heater
« Reply #3 on: July 01, 2019, 02:46:07 AM »
You are very welcome and keep us updated, someday I might try some aquaponics, that would interesting.
Re: Ibc heater
« Reply #4 on: July 01, 2019, 05:02:54 AM »
If you immerse a coil of pex in the tank, start and stop the flow through the coil with an aquastat or temp controller, then is a tempering valve needed?
Re: Ibc heater
« Reply #5 on: July 01, 2019, 07:09:37 AM »
I don’t think I would want 180 degree water running through the pex, better to temper it down close to the desired tank temp and go slow I would think.
