Pages: 1 [2]
Author Topic: G200  (Read 40005 times)
Re: G200
« Reply #15 on: August 13, 2019, 08:01:36 AM »
DHW first always then the furnace. You can get a little warm air out of 120 degree water, you won’t be getting any hot water from it though. DHW is the biggest although temporary load you have, biggest load first then the next lower load which would be the furnace HX.
Re: G200
« Reply #16 on: August 14, 2019, 03:41:41 AM »
I would agree. You won't like fluctuating shower temps but slightly changing air temps while using hot water is no big deal.
shepherd boy
  • OWF Model: C375
Re: G200
« Reply #17 on: August 14, 2019, 03:41:58 PM »
DHW first !!
Let the youngin's have it
 Gettin' old and lazy
Chevydmax6
Re: G200
« Reply #18 on: August 14, 2019, 07:59:26 PM »
Ok i have desided to do dhw first
On the furance my dealer said to use the bottom for the in
But i have talked to people  and they recommend  to use the top of it for in cause u want the air to leave the hottest  part last which make since
 Thanks for all the info and clearing thing up for me
Northern ohio
Re: G200
« Reply #19 on: August 15, 2019, 04:07:08 AM »
It'll heat either way but I try to pump into the side where the air exits. This makes the hottest air. Pumping in the bottom purges the air out the easiest tho.
Which brings me to another suggestion, especially if you push down through the hot air coil, plumb in a fill valve at the water heater and use it to blast the air out of the coil and lines. Otherwise it can take a bit to purge out using the pump on the stove.
Re: G200
« Reply #20 on: August 15, 2019, 06:32:09 AM »
Like Eldon said, you want the air leaving to see the hottest water last( incoming water). Air shouldn’t be to much of an issue to purge out by closing the return water valve at the boiler for 2-3 seconds while the pump is running and then quickly opening it. You repeat this until you don’t hear any more air bubbling back to the boiler.
Re: G200
« Reply #21 on: August 16, 2019, 05:32:16 AM »
I think I think about air purging more than most. Probably because we have such rough terrain and the stove can sometimes be much lower than a high point somewhere in the piping. Then air gets "hung" in the high spot.
Anyway, just a side note.
Chevydmax6
Re: G200
« Reply #22 on: August 16, 2019, 04:30:56 PM »
Ok i have been working on the insatll i got the rhinoflex  installed  the back of the stove is hooked up and i have pex ran  in the basement  to the hot water tank i will be running 1" copper from there to tie the furnace and dhw  in to finish the basement  install sunday
The stove is about 10' above the furance plus i am puting in a boiler drain valve in the basement  so i can take my water sample  from there plus i will start to fill the stove there and push the air out to the stove
Northern ohio
Chevydmax6
Re: G200
« Reply #23 on: August 16, 2019, 04:42:33 PM »
Here are some pics of the install i am doing
Northern ohio
Re: G200
« Reply #24 on: August 16, 2019, 10:00:48 PM »
What do you think of the Rhinoflex? I have a couple rolls of it on order but haven't seen any in person yet.
Chevydmax6
Re: G200
« Reply #25 on: August 17, 2019, 06:50:02 AM »
It does not bend easy but i never used anything else so i cant compare  it
Northern ohio
Pages: 1 [2]
