Author Topic: Water temperature sensor  (Read 8194 times)
Hippie44
  • OWF Brand: none
  • OWF Model: none yet
« on: November 07, 2019, 04:38:36 PM »
Do any guys know if there’s a clamp on water temperature sensor. The reason so I can keep track of the temperature from inside of the house. It would made it easier to know when to add wood. Thanks
Radio Tech1964
  • OWF Brand: Hawken Energy
  • OWF Model: HE-1100
  • Stihl MS 250 John Deere CS 36 2013
    • Weather Info
Re: Water temperature sensor
« Reply #1 on: November 07, 2019, 06:57:32 PM »
There's bound to be one but I can't recall right off. Ranco and Honeywell both make strap on Aquastats where you could come up with a GO.NOGO setup using different setpoints but would probably be pricey.  Might could strap a thermocouple from one of those wireless BBQ grill monitors if you're able to access brass or copper where you want to take your measurements. I have strapped sensors to PEX but even using a heat transfer compound the reading is quite a bit off from actual because PEX is a good insulator which is good for us in the long run.
Hope this might help!
WT
« Reply #2 on: November 08, 2019, 02:41:26 AM »
I've found taping a probe on the pex with foil tape and wrapping with insulation to be pretty accurate. But if the water temp is dropping you're a couple of hours too late.
Hippie44
  • OWF Brand: none
« Reply #3 on: November 09, 2019, 11:36:55 AM »
Thanks guys
