Author Topic: Wilo pumps  (Read 44972 times)
Wilo pumps
« on: December 06, 2019, 01:06:51 PM »
Just curious what you guys think of Wilo pumps. I've been using B&G and Grundfos. But I keep bumping into Wilos. We had trouble with some years ago and haven't considered them in quite a while. Thoughts?
Re: Wilo pumps
« Reply #1 on: December 06, 2019, 09:21:15 PM »
Ive seen em, but I’m a creature of habit, Grundfos always served me well and still do so no need to change. I may try a Wilo in the shop, I have a taco that’s getting noisy, whoever would have guessed.
Re: Wilo pumps
« Reply #2 on: December 07, 2019, 12:32:07 PM »
Also wondering who all is considering switching to ECM pumps. I haven't yet.
Re: Wilo pumps
« Reply #3 on: December 07, 2019, 10:12:25 PM »
I was using Armstrong ECM pumps for a while. I had a couple of them die so I went back to Grundfos 15-58 pumps. It was the electronics on both that died. The mechanical parts of the pumps looked like they were still in perfect condition. Both were in the back of G series stoves and both stoves had two but only one died. I am wondering if it is too hot in the stove for the electronics.
Re: Wilo pumps
« Reply #4 on: December 08, 2019, 06:22:56 AM »
I’ll give credit where its due, I have a Taco 013 Delta T pump on the G200 now, started out on the G400 in 2015, still working as of today.
Re: Wilo pumps
« Reply #5 on: December 08, 2019, 05:46:51 PM »
The taco 0013 isn't an ecm pump, is it? I thought it was just a regular type with variable speed control.
Out of 15 or 20 of the Armstrong ecm pumps, there were just the two failures that I know of.
Re: Wilo pumps
« Reply #6 on: December 09, 2019, 04:05:17 PM »
Not sure technically what you would call it, has a sensor on the supply and one on the return, then a dial that goes from 5-50F, I have the dial set at 20 and it speeds up or down to try and maintain a 20F Delta T.
wreckit87
Re: Wilo pumps
« Reply #7 on: December 18, 2019, 05:11:52 PM »
Have not had good luck with Wilo, even on closed systems. One of our suppliers sends Wilo with all of the Lochinvar and Slant Fin boilers we buy from them, and there hasn't been a darn one lasted more than a year. Most of them die within 6 months, a handful within a week. Bearings lock up on all
Re: Wilo pumps
« Reply #8 on: December 19, 2019, 04:55:39 AM »
Not worth the risk then I'm thinking. Thanks.
timbur
  • OWF Brand: Crown Royal
  • OWF Model: RS7400MP
Re: Wilo pumps
« Reply #9 on: December 24, 2019, 07:40:10 PM »
We use 100+ Wilo pumps per year and they have been holding up a lot better than the Taco , in open and closed loop systems
Dealer for OWB's &  specialize in radiant floor heat
Re: Wilo pumps
« Reply #10 on: December 28, 2020, 01:01:22 PM »
Bringing back an old thread hoping to see if there is any new info since then. The place I was getting Grundfos pumps from no longer sells them  so my costs will be a lot higher. Wilo seem to be priced decently and from what I found so far are not made in China. (looks like France?)
About 10 years ago they were considered trash but I thought I had heard they were a lot better now. I am wondering if part of that was because most people used to mount the pumps on the top connections on outdoor boilers and when going to the bottom happened to coincide with dropping Wilo?
The last few replies to this cancel each other out. LOL
Anyone used any in the last couple years with good or bad luck?
Re: Wilo pumps
« Reply #11 on: December 29, 2020, 03:02:11 AM »
I haven't used wilo since we got a few about 10 years ago and they mostly failed.
I'm using Grundfos now. And quite a few B&G. Theyve been great for years.
timbur
Re: Wilo pumps
« Reply #12 on: December 29, 2020, 02:37:44 PM »
Still using Wilo pumps and they've been holding up well
Re: Wilo pumps
« Reply #13 on: December 29, 2020, 03:13:05 PM »
Where are the ones you used made?
What models do you usually use? it looks like then 21, 30 and 32 would pretty much cover everything.
Having the 32 would be a good pump to sell as a Taco 009 replacement. i don't care for that flow curve but would be a lot easier than figuring out what the correct size is each time someone is replace those.
Radio Tech1964
  • OWF Brand: Hawken Energy
  • OWF Model: HE-1100
  • Stihl MS 250 John Deere CS 36 2013
    • Weather Info
Re: Wilo pumps
« Reply #14 on: December 29, 2020, 10:11:02 PM »
I have been looking at the Taco 0018E pump. It claims to allow the flow to be adjusted for the best balance using a Bluetooth app.
I haven't decided if there would be enough control to make any measurable differences in heat output. Secondly, it's kinda pricey as well.
Anybody have any experience with these yet?
WT
