Author Topic: Water filter  (Read 38941 times)
wormmister
  • OWF Brand: Wood Doctor
  • OWF Model: WDGS-70
Water filter
« on: January 27, 2020, 07:52:13 PM »
What type of water filter do you guys use ?
On the wood boiler side.
Thanks
Scratch
  • OWF Model: CB6048
    • Edge Metalworks
Re: Water filter
« Reply #1 on: January 27, 2020, 08:45:06 PM »
No water filter used here.
Hudson, WI
Re: Water filter
« Reply #2 on: January 27, 2020, 09:26:13 PM »
No water filter here, either.  I'd imagine most regular filters would add too much head to the flow and breakdown in the heat.  A spindown filter would probably not work so well, either.
Re: Water filter
« Reply #3 on: January 27, 2020, 10:36:28 PM »
These are the best I have seen. https://www.boilermag.com/na/products/residential/
Too expensive for most people to want though.
Re: Water filter
« Reply #4 on: January 28, 2020, 03:19:32 AM »
None for me.
Re: Water filter
« Reply #5 on: January 28, 2020, 07:26:27 AM »
A lot of people use Rusco’s. Personally all I have on mine is a wye strainer, which I’ve never found anything in it.
Walleye
Re: Water filter
« Reply #6 on: January 28, 2020, 07:41:30 AM »
I've had a couple Taco pump impellers disintegrate last year. Kind of wish I had a wye strainer to capture the pieces rather than wonder where they ended up.
hoardac
  • OWF Brand: Heatmaster G-200
Re: Water filter
« Reply #7 on: January 28, 2020, 02:28:28 PM »
Yeah I just run a wye strainer and clean it start of the season never really had much after first season.
WoodMOJoe
Re: Water filter
« Reply #8 on: January 29, 2020, 07:00:56 AM »
Wye strainer for me too.  Found a few little tiny pieces of stuff after the first year but nothing since.
Super44
  • OWF Model: Ultimizer BL 2840
Re: Water filter
« Reply #9 on: June 07, 2020, 07:13:31 PM »
Thinking of adding a filter but it seems the need is questionable??
wreckit87
Re: Water filter
« Reply #10 on: June 08, 2020, 08:35:33 AM »
None for me either, just a wye strainer which is always clear when I check it annually. I think your stove and piping along with treatment will determine the need for a filter, stainless stoves with barrier pex and proper treatment should never have any buildup to speak of but any mild steel system with plumbing pex will be more susceptible.
hoardac
Re: Water filter
« Reply #11 on: June 08, 2020, 04:25:05 PM »
Just a wye strainer cleaned once a year.
