Author Topic: shop install pics?  (Read 7376 times)
duke
  • OWF Model: MF5000
shop install pics?
« on: February 21, 2012, 08:37:11 PM »
Does anyone have any pics on how they have they're heat installed in shop? Trying to get some ideas. Thanks for any help.
06 Duramax
08 Polaris Ranger XP
MS 310
28 ton Swisher
Bull
  • OWF Model: Rebuilt H2
Re: shop install pics?
« Reply #1 on: February 22, 2012, 03:43:02 AM »
Welcome to the site Duke,I don't have any pictures but I will try to post some tonight. I gutted an old gas furnace to use as a air handler and added a water to air HEX on top, using an electric base board heater thermostat to control the blower.
Southern Indiana
BoilerHouse
  • OWF Brand: Home Built
« Reply #2 on: February 22, 2012, 03:46:22 AM »
No pic's but here is a brief description.  Shop is 30 x 24 - 9 foot walls central Ont. Water to air HX             is 16 x 18 (same size as the one for 1500 sq ft farmhouse)
HX is mounted on a wooden platform about a foot off the floor.  (Wanted to mount it low in order to keep it below the level of the expansion tank.). Got a cheap shop exhaust fan which came in its own frame and mounted it in front of the HX.  It draws air through the coil and blows it accross both shop doors.  Also installed a track in the back of the HX so a filter could slide in.  The fan is controlled by a 110 V thermostat which is close to the center of the shop and hangs down from the ceiling about 3 feet.  I keep the thermostat off when not in use and the heat that convects through the coil keeps the shop around 40.  It takes a couple of hours to make the shop comfortable when the shop is in use.
Muskoka, Ont
gmviso
  • OWF Model: CL5036
  • Northeast Indiana
« Reply #3 on: February 28, 2012, 08:40:27 AM »
This is how I am heating my 28x28 garage. It is a 16.5x21 HX with a Dayton Blower assembly attached. I mounted it to the ceiling joists using unistrut and 1/2 inch threaded rod. I have a Erie T.A.C. 3-way zone valve and a Honeywell R8285A1048 Fan Control which includes a relay which is mounted to a 4 inch box at the ceiling.
[attachment deleted by admin]
Central Boiler CL5036
