Pages: 1 2 [3] 4
Author Topic: My central air is coming on ?  (Read 37975 times)
Re: My central air is coming on ?
« Reply #30 on: October 29, 2012, 04:01:44 PM »
The fan switch on the old thermostat won't work. (I consider this a good thing because if it gets turned on it will overheat the house) There are a few furnaces and heat pumps that do require the G connection so I would turn on the heat and make sure the fan kicks on before leaving it that way. I have never seen one that did require it though but heatpumps are very rare around here.
« Reply #31 on: October 29, 2012, 05:05:05 PM »
This place is full of heat pumps, I'm gonna have to do a relay to cover myself I'd think
« Reply #32 on: October 29, 2012, 05:24:16 PM »
Just disconnect the g terminal an turn the heat on and if the blower starts like normal then you are fine.
« Reply #33 on: October 29, 2012, 05:30:27 PM »
So if the customer wants to use the heat pump, will his old stat still turn the fan on as normal
« Reply #34 on: October 29, 2012, 05:33:32 PM »
that is what you need to test. First thing is just remove the g wire and then turn on the heat pump and see if it works properly and the blower runs. Most will but some may require the G hooked up.
jerkash
  • OWF Brand: Legend
« Reply #35 on: October 29, 2012, 05:40:23 PM »
Hey SumpterSmoker - Are you confused yet??
Don't worry, these guys will get you straightened out.  They have helped me a lot!
« Reply #36 on: October 29, 2012, 05:51:12 PM »
Ok makes sense, but if I'm 90 minutes from home and that don't work.  Then what?  I'll need to install a relay somewhere
I wasn't aware the diodes changed the current
« Reply #37 on: October 29, 2012, 06:48:03 PM »
Well,if I was going to use a relay, I would get a SPDT with 24v ac coil.
I would cut the wire going to the G on the original thermostat and run the furnace end to the common contact connection and the thermostat end to the NC connection. Then run a wire from the NO connection to the RH.
Then run one side of the coil to the C on the thermostat.
Now for the new thermostat run a wire from the W to the other side of the coil. You will also need a jumper wire between the two thermostats on the RH terminals (and the C terminals if it is a digital thermostat that doesn't use batteries)
« Reply #38 on: October 29, 2012, 07:01:53 PM »
Good grief lol
The ones I use do have batteries..
I thought it would be as simple as splicing into the yellow wire so the signal couldn't back feed and outdoor unit wouldn't come on
« Reply #39 on: October 29, 2012, 07:09:15 PM »
Lol it isnt really that complicated. You cant have the relay cut the connection to the y if it is a heat pump. If you do the heatpump wont work unless you shut off the owb thermostat.
If i get time i will try drawing up a diagram.
« Reply #40 on: October 29, 2012, 07:38:10 PM »
 I use relays on all my jobs, its the only way to be certain you make heat pumps do exactly what you want them to do. The other day I used 4 relays, a zone valve and a 24v ranco to make a unit work properly. As a wise man once told me, you can run the world off 24v if you have enough relays.
 SumpterSmoker, hopefully I can explain how to hook your system up with a relay. I use http://www.google.com/imgres?q=white+rodgers+90-293q+wiring+diagram&hl=en&sa=X&biw=1024&bih=613&tbm=isch&prmd=imvns&tbnid=r2DzaH9wuEWaPM:&imgrefurl=http://www.johnstonesupply.com/storefront/hvacr-parts/controls/electrical-controls/hvacr-parts/controls/electrical-controls/relays/switching-relays//prodL36-905.html&docid=PkH2qVJr1spNSM&imgurl=http://www.johnstonesupply.com/storefront/renderImage.image%253FimageName%253DWEB/10010/L36-905cl.jpg%2526width%253D407%2526height%253D268%2526padding%253D0&w=407&h=268&ei=Ni6PULGHE4zC0AHfmoHwCw&zoom=1&iact=hc&vpx=101&vpy=166&dur=550&hovh=140&hovw=184&tx=125&ty=101&sig=112355657484556333735&page=1&tbnh=139&tbnw=182&start=0&ndsp=18&ved=1t:429,i:71 a white rodgers 90-293q. Hopefully this link works.
 The new thermostat should be linked with the old c to c and r to r, this powers the new thermostat. I normally install the relay in the blower unit. Run c from the unit to the #3 on the relay. Run a wire from the w on the new thermostat to both the #1 and #2 on the relay. Splice the wire from g on the old thermostat and hook the thermostat side to #5 and the furnace side to #4.
 If you want to understand how it works I can explain further, it is very simple.
« Reply #41 on: October 29, 2012, 07:44:45 PM »
Yoder do you run a whole new line set down to the blower too?
« Reply #42 on: October 29, 2012, 07:49:47 PM »
If you are asking if I run a new thermostat wire then the answer is normally no. 95% of the time not all the wires are used in the existing wire and I just use one of those.
« Reply #43 on: October 29, 2012, 09:14:01 PM »
Just curious, why do you run the W from the new thermostat to the #2 instead of the R? It will work the same, just wondering if there is a reason I am missing.
« Reply #44 on: October 29, 2012, 09:50:21 PM »
 You can do it either way, I just do it that way because its one less wire to hook up. The only time you need power on that terminal is when the relay is activated so I just run a jumper from #1 to #2 but you could get power for #2 from R. I have had a relay stick before and I guess the advantage there would be there would be no power on #2 if it did but you still wouldn't be able to activate the fan from the original thermostat if that happened.
Pages: 1 2 [3] 4
