Pages: [1] 2 3 4
Author Topic: My central air is coming on ?  (Read 37989 times)
sumptersmoker
  • OWF Brand: Centeral Boiler
« on: October 26, 2012, 01:24:52 PM »
I used the wiring diagram from Central boiler for the wiring of the second thermostat.. I have a forced air furnace with central air. The compressor fan keeps coming on ... what did I do wrong ?
Re: My central air is coming on ?
« Reply #1 on: October 26, 2012, 01:30:08 PM »
You need to take the wire off the G terminal on the original thermostat, not just add the new wire. Just splice it to the wire going to the new thermostat.
netwerx-r-us
  • OWF Model: Hoss 400HE
    • Netwerx-R-Us
« Reply #2 on: October 26, 2012, 02:14:24 PM »
would you be kind enough to share that diagram? , that actually was going to be one of my next posts to ask for that  , thank you sir
Netwerx-R-Us
http://netwerx-r-us.com
Echo 440
Honda Rancher 400
Kubota ZD326
jbc
  • OWF Brand: ridgewood
  • OWF Model: 7500
« Reply #3 on: October 26, 2012, 02:37:38 PM »
Lets call your old thermostat "thermostat A"...New one added to your system "thermostat B"
On thermostat A look for the G marked terminal, it should have your A/C wire hooked to it....REMOVE the wire going to the G terminal on Thermostat A.....
Next take the wire that is running from thermostat B (W marked one) and attach that to the "now" empty terminal G on thermostat A....wa'la your done---you will have the reverse the 2 wires in the spring for the A/c to work....there's other ways you can do this--but this is the easiest way.
Basically, the G terminal on a thermostat is the fan activation wire----when you do not unhook the A/C wire from thermostat A when you hook up thermostat B to it---the thermostat B wire backfeeds the A/C system and turns it on.
I'm a picture dunce on this forum..sorry
sumptersmoker
« Reply #4 on: October 26, 2012, 02:38:16 PM »
I just took the orginal thermostat off the wall and the compressor just stopped. Im not sure I understand what is going on but im not a HVAC guy ...
sumptersmoker
« Reply #5 on: October 26, 2012, 02:41:18 PM »
So did I just trash my compressor for the last 2 weeks my boiler was running ?
jbc
  • OWF Model: 7500
« Reply #6 on: October 26, 2012, 02:46:40 PM »
ok here is a nice posting also...still dont have a pictures for ya' but the internet should be your friend.
http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=1348.0
« Reply #7 on: October 26, 2012, 04:44:44 PM »
the G wire is for the fan. (Y is the compressor)
You need to remove the wire on thermostat A and leave it empty. Run the wire you took off the G terminal on thermostat A and run it to the W on thermostat B Then add a wire onto RH (leave original wire on this terminal too) of thermostat A and run it to RH on thermostat B.
Or you can just disconnect the wire from the Y terminal but then your AC won't work anymore.
sumptersmoker
« Reply #8 on: October 26, 2012, 04:56:32 PM »
I just took the wire from G on the old stat and ran  it into the w on the new one.. do I still need to disconnect the yellow on the old one... ?
tanner
  • OWF Brand: Legend
  • OWF Model: 4135
« Reply #9 on: October 26, 2012, 07:39:44 PM »
This is kinda what i had a ? about but im wona just use my old thermosat it has a off and cold and heat switch and when i turn the heat on my gas furnace kicks on i would like to un hook the gas furnace and make the fan come on with out my gas furnace trying to come on any ideas?
« Reply #10 on: October 26, 2012, 08:12:13 PM »
You don't have any wires on the G terminal on the original thermostat and the compressor is still coming on?
« Reply #11 on: October 26, 2012, 08:13:31 PM »
If you want to just completely disable the gas and use the existing thermostat, all you have to do is take the W wire off and move the wire from the G terminal to the W.
sumptersmoker
« Reply #12 on: October 27, 2012, 04:15:39 AM »
I think I got it ... I just have to switch the wires back for cool air... Now do you think I did any harm to my compressor ?
Jack72
  • OWF Model: E-1450 (11)
« Reply #13 on: October 27, 2012, 05:16:44 AM »
Hello RSI.
I've been wondering about this      This may be a stupid question.  But I've always just shut the breaker off to the ac   And just turn back on in the summer is this a bad thing or just a easy way out      I haven't ran mine OWB in the summer yet so it's not a issue for me right now     Thanks for any input you can give
Thanks Jack.
Chevy 2500 HD 13 Duramax
Stihl 046 036 009
Northern Tool 25 ton Splitter
lasor1
  • OWF Brand: Heatmaster ss
  • OWF Model: Heatmaster mf 5000
« Reply #14 on: October 27, 2012, 06:36:31 AM »
You can put a diode on wire going to tstat to keep power from back feeding old tstat that would work too! Without changing anything but I like the relay deal it will keep them isolated from each other and I will probably change mine to relay in future but no problems here with diode inline
Pages: [1] 2 3 4
