Pages: 1 2 3 [4]
Author Topic: My central air is coming on ?  (Read 38018 times)
Re: My central air is coming on ?
« Reply #45 on: October 29, 2012, 09:56:04 PM »
That makes sense.
How often do you run into a system that does need the G wire to operate though? I bet most of the time just removing the wires from the G and splicing together would work fine.
« Reply #46 on: October 29, 2012, 10:06:52 PM »
95% of what I do is heat pumps so many do need a relay. When I do a gas or oil furnace I often do something different depending on the situation. I should mention doing this to a variable speed fan will only get you low speed.
« Reply #47 on: October 29, 2012, 10:13:43 PM »
Wow, never realized it was that much different in other parts of the country. Almost all LP or fuel oil forced air furnaces around here. Almost everything else is gas or oil boilers but they are way less common.
« Reply #48 on: October 29, 2012, 10:20:58 PM »
 I'm in Virginia where are you located?
« Reply #49 on: October 29, 2012, 10:21:24 PM »
Wisconsin
« Reply #50 on: October 29, 2012, 10:26:21 PM »
 Never mind, I see you are in Wisconsin. I'm sure you have much harsher winters. I most likely see about 95% heat pumps/electric furnaces, 2% gas furnaces, 2% oil furnaces and 1% oil or gas boilers. New homes around here are almost 100% heat pumps. I think this year I have only seen one boiler and one oil furnace so far, everything else has been heat pump.
« Reply #51 on: October 29, 2012, 10:49:57 PM »
Nearly the same in my area to, folks fail to realize it's to cold in this area for heat pumps and wind up paying out the wazoo
Pages: 1 2 3 [4]
