Author Topic: ge hybrid water heater and plate exchanger help  (Read 5377 times)
jborden3
  • OWF Brand: tennessee outdoor
  • OWF Model: hoss 400
« on: December 24, 2012, 10:01:35 AM »
I have a ge geo spring water heater it is a heat pump hybrid dose any one know if it is ok for me to just run stright in to it with my water out of my plate exchanger?
Re: ge hybrid water heater and plate exchanger help
« Reply #1 on: December 24, 2012, 11:33:40 AM »
Elaborate a little more, not sure what you mean
jborden3
« Reply #2 on: December 24, 2012, 02:51:51 PM »
Would like to know if i have to put a thermostatic mixing valve on the cold water side so i am not running 180 deg water in to the heat pump or can i just run it straight in and put my mixing valve on the hot water side was worried with all the electronics on this thing it might go crazy when it start getting that hot of water in to the heat pump coil
« Reply #3 on: December 24, 2012, 09:11:20 PM »
I have no idea what you have, but when running a 20 plate hooked to a hot water tank I don't install a mixing valve, water can only get to like 130 unless you would let it slowly leak through the plate, unlike a side arm that can match boiler temps
