Author Topic: Iced up chimney  (Read 17796 times)
Iced up chimney
« on: January 31, 2013, 05:53:19 PM »
When I left this morning there was ice all over my chimney cap, I forgot to take pics but when I got back in this evening there was still some on it but most was gone!!
Really wish I woulda took the pic this morning, if it happens again, I will
Bondo
  • OWF Brand: Home built
  • Master General Re-Engineer
Re: Iced up chimney
« Reply #1 on: February 01, 2013, 08:01:11 AM »
Ayuh,.....   When it's bitter cold out, Mine'll do that for the first few cycles, after I load it,...
I believe it's just the steam off the fresh wood, til it drys out, 'n starts to carbonize...
Re: Iced up chimney
« Reply #2 on: February 01, 2013, 08:15:49 AM »
What kind of boiler you have?
It's def moisture out of the wood, but I've never seen it freeze as much as it was yesterday am, it was 10x that
Bondo
Re: Iced up chimney
« Reply #3 on: February 01, 2013, 09:42:49 AM »
Ayuh,....    Homemade,...
The colder it is, the more mine does it....
Brad
  • OWF Model: H5
Re: Iced up chimney
« Reply #4 on: February 01, 2013, 10:42:12 AM »
I just googled "Ayuh" and now know what it means...  Never seen that before....
BTW, I like your homemade boiler!
Aitkin, Minnesota
Bondo
Re: Iced up chimney
« Reply #5 on: February 01, 2013, 10:53:48 AM »
Ayuh,....   I'm a Maineiac in exile over here on the Sweetwater Seas,....
Thank you on the boiler project,...
My only regret is it took me 10 years longer than it should have, 'n I'm out well over $20,000.00 because I started it, 'n didn't finish it sooner...
Good thing is,...   I ain't burnt Oil in over 3 years now...   ;)
bajonesy77
  • OWF Brand: Prosteel
  • OWF Model: 200
Re: Iced up chimney
« Reply #6 on: February 01, 2013, 01:20:36 PM »
Has anyone else noticed there is a hand on the loading door?  Thats definitely different bondo please explain whats this hand is all about. Door latch?   :o
Brave 22 ton splitter
Stihl 440 magnum 20" bar
Stihl 390 20" bar
AirForcePOL
  • OWF Model: G400
Re: Iced up chimney
« Reply #7 on: February 01, 2013, 01:23:57 PM »
lol yeah I noticed that too.  ayuh... Bondo, tell us how much Bondo you sniff on an average day...
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
Bondo
Re: Iced up chimney
« Reply #8 on: February 01, 2013, 03:07:24 PM »
Ayuh,.....   It's the door Handle of course,...   :thumbup:
This is gettin' Way off topic,...   This is Scott7m's thread,...   Not mine....
I'll try to dig up a bunch more photos of the build, 'n do a thread for myself...
I Hate doin' bodywork with Bondo,....  though I do abit of Boat glassin'....
It's a conflagration of my name....
So I am not the only one who had to google "ayuh"! LOL
Ayuh,...   This's usually the answer I offer, when questioned 'bout it...
'Google is yer friend, Google it"...
I was born, 'n raised in the northwestern most Downeast Maine...   ;)
Re: Iced up chimney
« Reply #9 on: February 01, 2013, 03:08:57 PM »
Don't worry about my thread lol no big deal
Bondo
Re: Iced up chimney
« Reply #10 on: February 01, 2013, 03:14:14 PM »
Ayuh,....   After yer Welcome last week, no way in 'ell I'm gonna hi-jack Yer thread....
Wow bondo,
Why are you on here throwing out such ignorant comments????
Do you have any facts to back up anything you say?  Such as dead water?  Or the comment "won't rust hardly as bad"
Wow is all I can say
Re: Iced up chimney
« Reply #11 on: February 01, 2013, 03:36:36 PM »
Well since you brought it back up, still wanting to hear some proof of terms like "dead water".
Or how wont hardly rust as bad is a good thing?  How about no rust?
Oh yea, and we can't forget that boiler treatment is snake oil
2 nails, 2 plastic cups, 2 drops of treatment, in a matter of days you'll see which nail is rusting away and which one looks like new.    If you want you can even heat the water up first to make it dead
Bondo
Re: Iced up chimney
« Reply #12 on: February 01, 2013, 04:44:03 PM »
Ayuh,....   My boiler is run tied to the house boiler....
Same 12 psi system, same water....
When the system water is repeatedly heated, 'n pumped, dissolved gases are purged from the water...
Mine more so/ better than others, because I have a spiro-vent at the outlet of each boiler, 'n pump away from it...
The spiro-vent knocks out the dissolved gases even quicker... the low-pressure point caused by the pump helps even more,...
After a short time in the system, the water is pretty damn Dead,...
a fish sure as 'ell would die, as there's No dissolved Oxygen in it,...
No free Oxygen,....   No rust....
I concede that I wrote from My Own Experiences, 'n I didn't think of the fact that many or even most of you are runnin' Open systems....
I shoulda been more clear that, My system don't need any Snake Oils.... :)
I'll also note, I'm a single digit typist, 'n my words are short for their meanin's...
Ignorant Comments is/ was Over the Top,....   :o
Askin' 'bout My comments in the appropriate thread woulda been a 'ell of alot more civil don'tcha think,..??   ::)
« Last Edit: February 01, 2013, 05:05:19 PM by Bondo »
Re: Iced up chimney
« Reply #13 on: February 01, 2013, 05:14:19 PM »
Ok, u r right as far as a closed system under pressure, that makes a huge difference, but I would say 98% of members here are open systems.  I later thought maybe you thought we were all pressurized...
What temps do you run your boiler at?
J Cooch
  • OWF Model: Cb5036
Re: Iced up chimney
« Reply #14 on: February 01, 2013, 06:31:58 PM »
I run the same water with no exchangers in an open system, the pressure for the indoor boiler is created by restricting the(return valve) flow being forced by the taco 009 pushing water from the outdoor boiler thru the inside furnace. The return valve is after the inside boiler and when it is open all the way i have no pressure at the inside boiler. I restrict it until I have 12psi inside.  I use corrosion inhibiter and the water is always nice and clear. So far the taco 009 has lasted almost five years providing 12psi to the inside boiler while running 24/7. Happy that I never spent the money on exchangers. Also happy I put inhibiter thru my indoor furnace as the original water was from my well unfiltered, and full of iron. So far all works great.
