Author Topic: Set-Back Recommendations  (Read 10744 times)
CountryBoyJohn
  • OWF Model: MF 10,000 E
« on: February 25, 2013, 02:38:27 PM »
After searching around this site, consulting with my insurance agent, and exploring an installation manual, I have not been able to come up with any solid recommendations for good set-back distances for the OWB from a house.  Insurance agent said what ever the manual says.  Manual says keep 36" away from anything flammable.  Nothing very specific on how far away from the house to locate the boiler.
It is shaping up for the best place to locate my boiler is directly behind my semi-detached garage.  Close enough that my return/supply lines will go from the back of the boiler directly through the wall into my garage without having to be burried.  I have a slab floor and coming up from the gound is not feasible.  My plan is an insulated connection on the exterior of the wall via the method that has been shown on this site a couple times before in other threads.
Any thoughts?
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
Re: Set-Back Recommendations
« Reply #1 on: February 25, 2013, 02:48:33 PM »
There isn't a set answer I don't think.  Most books will say 36" from a flammable surface or something like that, I would likely just set it out from your shop 6' or so to give plenty of room to access the back of the stove comfortably.  I wouldn't be worried about it hurting anything, if I were that close though I'd def extend my chimney up some though
CountryBoyJohn
« Reply #2 on: February 25, 2013, 03:05:33 PM »
Ok.  Here is what I'm looking at specifically.  (see attached PDF)
Stihl MS290
Woodchuck Log Jack
Knox County, IN
fireboss
« Reply #3 on: February 25, 2013, 03:11:30 PM »
my building inspecter said that it has to be 12' away from my house so i went 14' to keep him happy!
« Reply #4 on: February 25, 2013, 03:24:12 PM »
I've never seen a building inspector in my area but just go with whatever the manufacturer says is ok....
Make sure it's listed for insurance purposes
mikey37
  • OWF Brand: Ridgewood Stove
  • OWF Model: 7500
« Reply #5 on: February 25, 2013, 04:00:35 PM »
Not all insurance companies require listing!
« Reply #6 on: February 25, 2013, 04:03:43 PM »
That's true, but at the same time, if I were sitting it within 4 feet of a building, I'd hate to give a lawyer a toe hold
« Reply #7 on: February 25, 2013, 04:04:57 PM »
Let me make it clearer, I wouldn't worry if it was out in the yard, but sitting it so close if wanna make sure i was covered, in 99% of owb installs, a ul listing is worthless to me
WoodMOJoe
« Reply #8 on: February 25, 2013, 04:20:19 PM »
My insurance company required 10' clearance from the house.
Since mine is an air furnace I wanted to stay as close as possible.
No UL listing since it was homemade.
plumb bob
  • OWF Model: CL 5036
  • still green
« Reply #9 on: February 25, 2013, 04:53:41 PM »
10', just enough for my trailer to slide through. :thumbup:
Trint
  • OWF Model: ml 30
« Reply #10 on: February 25, 2013, 05:54:09 PM »
My insurance was 25ft or pay more, gives smoke close to enough time to get up, have another piece of pipe to go on once i get it braced.  If go close plan on adding some extra pipe to it.
North Central Ohio
johnybcold
  • OWF Model: Classic E1400
« Reply #11 on: February 25, 2013, 06:20:34 PM »
State of MA has a setback not sure what it was because I had plenty I know it has to be 50ft from property lines and like150 ft from another house
old truck
old craftsman chain saw
Polaris Sportsman 500HO
« Reply #12 on: February 26, 2013, 02:14:13 PM »
When I was thinking of installing the OWB, I called my local zone enforcement officer and inquired regarding town local zoning law.  He said they go by manu. recommendations.  I called my CB dealer who said between 20 and 30 feet from the nearest structure which happened to be my house, so I set it back 25 feet.  So, if ever you're in Enfield, NH...you now know the rest of the story.  Roger
« Reply #13 on: February 26, 2013, 04:28:47 PM »
Insurance companies...The biggest scam they are..
