Author Topic: door solenoid  (Read 8511 times)
chiselchain
door solenoid
« on: November 03, 2013, 02:31:50 PM »
I have a ridge wood stove. i looked out the window and seen steam coming out.
  so i run out there and the damper door is stuck open. it got up to 212 but i didn't lose all the water but this has me worried. should i be spraying some wd40 on that solenoid? has anyone had this happened to anyone else?
Re: door solenoid
« Reply #1 on: November 03, 2013, 02:41:36 PM »
Spray it with some oil and manually work it up and down and spray it again
I had a heatmaster overheating due to a solenoid that had some surface rust on it the other day, cleaned it and it fixed it
chiselchain
Re: door solenoid
« Reply #2 on: November 03, 2013, 02:43:47 PM »
thanks scott. you don't think any damage was done to the stove would you? its only been running for a little more then a month
Re: door solenoid
« Reply #3 on: November 03, 2013, 02:44:34 PM »
WD-40 will help right away but it will promote rust in the very near future, my advice would be wd-40 for now and when you get it freed up use a few drops of automatic transmission oil or maybe even gun oil if you are one of us crazy gun owners. The stuff stays very slippery for a long time in the weather and has anti corrosive stuff already in it.
Re: door solenoid
« Reply #4 on: November 03, 2013, 02:46:19 PM »
no way would it hurt it, but slim is right about wd40
initially its ok but long term its junk
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
Re: door solenoid
« Reply #5 on: November 03, 2013, 03:55:46 PM »
I use Aero Kroil  penetrating oil on mine. works good
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
Re: door solenoid
« Reply #6 on: November 03, 2013, 04:23:08 PM »
AUTOMAN do you own a gun?
Re: door solenoid
« Reply #7 on: November 03, 2013, 04:25:14 PM »
i thought you were supposed to get a gun before a chainsaw
Re: door solenoid
« Reply #8 on: November 03, 2013, 04:28:03 PM »
Especially if you own and operate a WOOD BOILER
automan77
Re: door solenoid
« Reply #9 on: November 03, 2013, 05:22:52 PM »
sure do
Scott K
Stihl ms 311
Husky 455
Re: door solenoid
« Reply #10 on: November 03, 2013, 06:04:48 PM »
Welcome to the club
baldwin racing
Re: door solenoid
« Reply #11 on: November 03, 2013, 06:12:02 PM »
why own one when you can own more? ;)
kelly
husqvarna 357 xp
farmall H
doow14
  • OWF Brand: shaver
  • OWF Model: 165
Re: door solenoid
« Reply #12 on: November 04, 2013, 05:28:26 AM »
sure wish I could still find/afford ammo for them cant even hardly get 22 lr's any more
"Some People Don't Know, And The Problem Is They Don't Know That They Don't Know"
