Author Topic: system setup  (Read 7369 times)
Marktk
  • OWF Model: Mf5000
system setup
« on: November 08, 2013, 11:44:50 AM »
Does anyone see a problem with the having my system set up like this. Water in from boiler to sidearm on dhw then to a gas water heater(storagetank) the back to the boiler i did notice that when my floor heat turns on i will some times be returning 140-150 to the boiler. The floor heat pulls from the gas storage tank from hot and cold outlets the boile is tapped into the relief and drain outlets.
Re: system setup
« Reply #1 on: November 08, 2013, 03:56:20 PM »
What are the entering temps from the boiler start at? If they come in at 180 and drop to 140-150 that is to much of a heat drop I believe. When I was putting my system together I believe the ideal drop is right about 20 degrees. If you are having a greater drop than that you need to move the water faster through the system.
Re: system setup
« Reply #2 on: November 08, 2013, 05:19:50 PM »
Understand that what you have just created is a buffering tank and not a heat exchanger
Marktk
  • OWF Model: Mf5000
Re: system setup
« Reply #3 on: November 10, 2013, 06:14:04 AM »
yes i have a buffer tank also would be used as a backup if nessasary  i have a 20 degree drop though my floor loops but when they kick in my tank drops  dramaticly for a short time
Re: system setup
« Reply #4 on: November 10, 2013, 08:56:40 AM »
Yes and all the ports on the tank are 3/4 inch with only thermal siphon on the sidearm to produce the heat or is there a coil in the gas fired water heater
Marktk
  • OWF Model: Mf5000
Re: system setup
« Reply #5 on: November 10, 2013, 11:43:16 AM »
the tank has four opening so  the floor pump runs though two and the owb pump runs thru the other two   the side are is on my dhw
Re: system setup
« Reply #6 on: November 10, 2013, 04:23:55 PM »
When you say returns of 140 -150 to the boiler, you are talking about the returns from the radiant to the tank and not the diff on the boiler loop
Marktk
  • OWF Model: Mf5000
Re: system setup
« Reply #7 on: November 13, 2013, 10:44:07 AM »
Thats return to the boiler which gives me about 30 drop at boiler
