Author Topic: Gurgling noise?  (Read 24671 times)
mingom
Gurgling noise?
« on: January 20, 2014, 06:38:59 PM »
Hey guys,
Went out to check the boiler tonight, checked the water when I was out there - no issues, but I can hear a bubbling or gurgling noise - temp was only at 176-178, has only gone up to 185 recently so I'm not sure it boiling - has anyone heard this before?
tawilson1152
  • OWF Brand: Crown Royal
  • OWF Model: 7300
Re: Gurgling noise?
« Reply #1 on: January 20, 2014, 06:53:51 PM »
I hear it every time my boiler fires.
tawilson1152
  • OWF Model: 7300
Re: Gurgling noise?
« Reply #2 on: January 20, 2014, 06:56:55 PM »
Water boiling. I've played around with switching the pipe connections, running at a lower temp and running two pumps for more flow but I still get it. I am used to it now.
willowbk
  • OWF Brand: port/main
  • OWF Model: 250
Re: Gurgling noise?
« Reply #3 on: January 20, 2014, 08:50:18 PM »
mingom
I have a port/main owf, all of the sudden I heard same noise coming in at return line and bubbling up from bottom to the top.
I was able to see return and supply line in the basement and could see air going back on return but not on supply. long story short, I had a drain valve that went bad and was sucking air on return side after exchanger, plumber said it happens occasionally. I caulked up and it went away. will replace in the spring.
Re: Gurgling noise?
« Reply #4 on: January 20, 2014, 10:21:34 PM »
mingom
Do you have the pump on the return side pulling the water?
Re: Gurgling noise?
« Reply #5 on: January 21, 2014, 05:13:18 AM »
Good catch and good post Willowbk
mingom
Re: Gurgling noise?
« Reply #6 on: February 16, 2014, 07:57:43 PM »
Been awhile, been monitoring it a bit... Think it's just boiling but it's weird- it can happen from170ish on up if there's a roaring fire.  Just sounds like the whole tank is rumbling/boiling.
Re: Gurgling noise?
« Reply #7 on: February 16, 2014, 08:20:45 PM »
I've heard a gurgle or two if air has somehow gotten in the lines. With a blazing fire it sounds more like when you're heating a pan of water on the stove, a sizzle actually.
Ratchet Thunderbolt
  • OWF Brand: Global Hydronics
  • OWF Model: GH-2000
Re: Gurgling noise?
« Reply #8 on: February 16, 2014, 09:00:35 PM »
mingom
What side should the pump be on?  With the house on the pressure or suction side?
Re: Gurgling noise?
« Reply #9 on: February 17, 2014, 04:25:05 AM »
I normally install the circ on the supply to the house side and as I have posted before I bring the return back to the hottest portion of the boiler, conventionals to the top and gassers to the bottom, I think this helps to stabilize the temps in the boiler.
mingom
Re: Gurgling noise?
« Reply #10 on: February 17, 2014, 08:31:35 AM »
My pump supplys to the house - on the lower side of the boiler, return on the top.  Its not air in the lines or anything like that -it only happens when it gets hot (generally 175+) but have heard it down to 170.  It only seems to happen when the fire is really ripping inside.
Re: Gurgling noise?
« Reply #11 on: February 17, 2014, 09:12:57 AM »
Water level is up? you are boiling your water and this is not good for the boiler, can you increase the water flow, larger circulator or if it's 3 speed try running it on high.
mingom
Re: Gurgling noise?
« Reply #12 on: February 17, 2014, 01:54:17 PM »
Water level is good - just checked.  Bumped the 3 speed grunpfos up to high - I'll see what happens with that.
djc
  • OWF Brand: Wood Master
  • OWF Model: 440
Re: Gurgling noise?
« Reply #13 on: February 17, 2014, 02:15:21 PM »
My 4400 does the same thing - Like you said, only when the fire is cooking good - It seems the sound is close to the front of unit - I think it is just a hot spot , where the fire is licking the side wall intensely in one location causing the water to boil, just in one spot.
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
Re: Gurgling noise?
« Reply #14 on: February 17, 2014, 04:43:08 PM »
Hey what does that mean when water is boiling below 212 degrees. How can that be? Systems sucking air into the pipes?
Michigan Thumber
