Author Topic: Water Pump  (Read 6280 times)
JDfarmer
  • OWF Brand: NCB 250 coal
  • OWF Model: NCB 250 Coal
Water Pump
« on: September 15, 2014, 06:39:54 AM »
Which water pump do you guys recommend?
I have a NCB-250/ nature comfort.
Currently it has a Broeder Pump 3 speeds: 0-20gpm $195.00, but I want to buy a back up one in case it breaks during the winter.
Nature comfort recommends the Broeder, which is the one the boiler comes with or they have for the NCB 250;
1. TACO 0-41gpm $413.00
2. Grundfos 0-17gpm $147
3. Armstrong E9 0-38gpm $309
I guess I could buy some other from Manard too.
Thank you
Steinacher Sales
Re: Water Pump
« Reply #1 on: September 15, 2014, 09:13:17 AM »
JD,
It depends on your distance and head-feet resistance!
Greg Steinacher
618-401-0726
www.midwestoutdoorfurnace.com
Chas
Re: Water Pump
« Reply #2 on: September 15, 2014, 10:03:23 AM »
I've had good luck with Bell and Gossett pumps, at work and on the OWB. I run an NRF-25 3-speed on the short run (50 ft.) to the shop and an NRF-36 3-speed for the 180ft. run to the house. I run them both on the #2 speed.
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
JDfarmer
Re: Water Pump
« Reply #3 on: September 15, 2014, 10:42:26 AM »
I forgot to post the distance;
I heat 4000sqft, NCB-250coal, water, and heat. Worked great least year.
The boiler is about 90 feet from the house, flat surface. My line is 9 feet underground. Currently I am running the Broeder Pump 3 speeds: 0-20gpm pump on speed 2, and it worked great last year. I just don't think that it's a very long lasting pump, so I was looking for something better.
What's better? have higher flow or slower flow? I was thinking high flow so the water temp doesn't drop as much as it goes thought the water tank, and the central air exchanger.
There is 0 temp drop between the boiler and the house; if the central heat fan is on, the water temp drops about 15-18F as it goes through the air exchanger.
thanks
JD,
Greg Steinacher
618-401-0726
« Last Edit: September 15, 2014, 10:44:02 AM by JDfarmer »
