Author Topic: Brushes  (Read 5931 times)
american-pacemaker
  • OWF Brand: P & M
  • OWF Model: OPTIMIZER 250
Brushes
« on: January 14, 2015, 04:58:39 AM »
Where do you guys get brushes for an optimizer 250. The brushes from the factory are too small for the tubes. What size brushes
do you use ?
GLOCKED
  • OWF Model: Optimizer 250
Re: Brushes
« Reply #1 on: January 14, 2015, 08:04:21 AM »
I bought some from Mcmaster Carr. The 2" works great. The 1 1/2 is a little small but cleans them out fine. I should've bought the next size bigger just to try it, but did not. With burning good dry wood this year there is only very fine ash in the tubes. If you have anything other than fine ash, my guess is your wood is to wet!
James
Re: Brushes
« Reply #2 on: January 14, 2015, 12:19:29 PM »
Torringtonbrushes.com
The 2" will definitely work for the vertical tubes but the 1.5" is slightly too small for the horizontal tubes. Go with 1 5/8" -they'll work much better. The brushes go for about $7-8 each. I usually get 2-3 at a time to make the $9.99 shipping cost worth it. They also have 3', 4', & 6' fiberglass rods that mate up with the brushes.
