Author Topic: 30 plate bell & Gossett heat plate big enough  (Read 9314 times)
Gilks
  • OWF Brand: none yet
  • OWF Model: none yet
« on: February 03, 2015, 06:21:39 AM »
Guys,
I bought a 30 plate bell & gossett heat exchanger for my domestic hot water. rated at 40,000 BTU. Is this big enough for an average sized house. Will it fill a whirlpool tub sufficiently?
Re: 30 plate bell & Gossett heat plate big enough
« Reply #1 on: February 03, 2015, 08:49:44 AM »
As much as number of plates overall size also plays a large part. Is it a 5" x 12" or is it a smaller size physically?
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
« Reply #2 on: February 03, 2015, 10:49:48 AM »
I had a small 10 plate on my 40 gal tank and it was useless :o
Aic 10 plate 3x 7 inches my $#%&S was warmer
« Last Edit: February 03, 2015, 11:04:30 AM by kommandokenny »
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
Gilks
« Reply #3 on: February 03, 2015, 11:07:11 AM »
oh crap!!!! it's a 10 plate, B&G 400-10, dimensions are 3.1 wide and 8.2 tall. Honestly, am i screwed? If this thing will not fill up a decent sized whirlpool tub I am dead. other recommendations? Also, best place to buy?
kommandokenny
  • OWF Model: 4400
« Reply #4 on: February 03, 2015, 11:13:39 AM »
I'm no expert but check this thread .
http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=6915.0
I use a side arm now .
You can use the 10 plate and plumb it into a side arm and have both going, that will work .
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
« Reply #5 on: February 03, 2015, 01:50:22 PM »
Problem with 10 plates is they restrict the boiler water flow way too much. You can sometimes get by with them if you use a much larger pump than you should need but if you already need a large pump then you are out of luck.
It is only $150 for a 5x13 20 plate that is made in USA. I don't see the point in trying to use something smaller.
« Reply #6 on: February 04, 2015, 02:50:25 AM »
I totally agree with RSI on this one, why bother with something that you already know is marginal?
U.P. Doug
  • OWF Model: 7500
« Reply #7 on: February 04, 2015, 03:44:20 AM »
I have the 20 plate that RSI is referring to. It works great, endless hot water. I put a bypass before it and installed boiler valves below the bypass so I can back flush the exchanger with a garden hose without taking it out.
« Reply #8 on: February 04, 2015, 06:21:06 AM »
Get yourself some combo units from supply house, can be had in sweat or threaded, units with a union built right in can also be had. By time you buy a couple separate valves, a tee, hose bib, etc it's hard to beat the price on them.
http://www.supplyhouse.com/Webstone-50614W-1-SWT-Webstone-PRO-PAL-Ball-Valve-w-Drain-Lead-Free
« Reply #9 on: February 04, 2015, 06:39:54 AM »
 :post:
These valves maybe a tad more than other, but they save a TON of space  :thumbup: :thumbup:
kommandokenny
  • OWF Model: 4400
« Reply #10 on: February 04, 2015, 07:11:21 AM »
Hose end complies with ANSI B1.20.7
I take it you can slap a standard garden hose on this ??
No way it comes with 1 in pex fittigs? ;D???
Some one will come up with it someday I guess
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
« Reply #11 on: February 04, 2015, 08:16:48 AM »
Garden hose or if your using a puddle pump use a washing machine hose as it will already have two female garden hose ends
kommandokenny
  • OWF Model: 4400
« Reply #12 on: February 04, 2015, 09:11:07 AM »
THANKS
Just want an emergency drain in case of pump failure.
Water could freeze at back of stove pretty quick here.
sorry for the side track guys
kk
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
