Author Topic: flushing exchanger?  (Read 5874 times)
novaman
  • OWF Brand: woodmaster
  • OWF Model: 434
flushing exchanger?
« on: February 08, 2015, 07:34:03 PM »
I have been useing my woodmaster 434 for 12 years now and last two year it doesnt seem to keep up on cold night, below 10deg its hard to hit 70 in house. used to be real hot. Im wondering if my exchanger is getting plugged up, I thought about  reversing lines or unhooking and flushing with hose like a car heater core. anyone ever have this issue of plugging up?
Re: flushing exchanger?
« Reply #1 on: February 09, 2015, 02:41:29 AM »
Yes they do plug up over time, I would also check the supply and return temps on the underground pipe as well, you may have water infiltrating the insolation of those lines.
kommandokenny
  • OWF Model: 4400
« Reply #2 on: February 09, 2015, 05:33:07 AM »
Theres a bit more with regards to cleaning out your exchanger here.
Fella took xch. to a place that services industrial boilers
kk
http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=800.0
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
novaman
  • OWF Model: 434
« Reply #3 on: February 09, 2015, 06:49:57 AM »
thanks for info, think i will add some vinager for now and in the spring unhook lines at exchanger and see if its plugged and if so remove to have it cleaned. I use well water and not thru a softner, but change it yearly and use additive from woodmaster. i guess over 12 years things happen
« Reply #4 on: February 09, 2015, 07:19:11 AM »
If you add vinegar now, I woudl suggest adding a filter or strainer of some kind casue all that build up is going to go some where (probably back into stove unless you filter or flush it out. JUST MY $0.02
