Pages: [1] 2 3
Author Topic: screw cone splitter  (Read 40811 times)
rosewood
screw cone splitter
« on: April 07, 2011, 07:32:00 PM »
anyone ever use a cone style splitter?  the ones the rednecks use on the rear end of their pickups :bag:I would like to buy the cone screw and adapt it use on skidsteer.
merrellroofing
Re: screw cone splitter
« Reply #1 on: April 07, 2011, 07:34:21 PM »
I know a guy that was running one and got his pants hung on it and ended up having to get his leg cut off from the knee down.
« Reply #2 on: April 07, 2011, 08:22:43 PM »
I am going to get one as soon as I find the right size hydraulic motor. I am going to try mounting it on the front of my Kubota RTV. Even if it doesn't work real well it will still be worth it because I bust up the larger pieces of wood instead of having to lift them.
If it doesn't work out on the RTV then I will re-do it for the skid steer.
As long as I am sitting on the seat holding a lever it should be a lot safer than a regular type splitter.
I plan on getting a wheel motor and a cone that bolts to a wheel hub. Then all I need to do is build a small frame that connects to the plow mounts.
NewToIt
  • OWF Brand: Wood Doctor
« Reply #3 on: April 08, 2011, 08:11:12 AM »
How about this one....   http://www.thestickler.com/articlee333.html?id=5833
Don't even know what to think/say about it, other than you can drive your splitter to/from the woods, then out to dinner and a movie later in the evening!
« Reply #4 on: April 08, 2011, 08:25:18 PM »
Seen a utube video with that type of spitter on a bobcat..Didnt seem very efficient to me..Funny seeing it hooked up to a truck..I think I'll stick the splitter I got..Way cheaper to run lol
« Reply #5 on: April 08, 2011, 08:57:45 PM »
I wouldn't have anything to do with one that required being by it while it is running.
kegelspalter hydrospalter wood splitter hydraulic log splitter
« Reply #6 on: April 08, 2011, 10:24:15 PM »
The one on the truck, if it got a hold of you you couldn't stop it before it hurt you. Looks to dangerous. The other one looks like it would splinter the wood to bad.
Scratch
  • OWF Model: CB6048
    • Edge Metalworks
« Reply #7 on: April 09, 2011, 04:44:15 PM »
I rented one once... here's the thread with my review:
http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=184.msg1342#msg1342
Hudson, WI
rosewood
« Reply #8 on: April 11, 2011, 07:45:19 PM »
not to worried about the danger issue..i will be sitting in machine,RSI i plan on useing a 32 to 1 ratio gear box with hydraulic motor driving that. only need to split the real big stuff so speed isn't a factor. does any one own one? makes sense to by one with replaceable tip but not sure if one is better then the other.
« Reply #9 on: April 11, 2011, 07:54:28 PM »
What speed is the hydraulic motor you will be using? You need at least a couple hundred RPM. This one appears to be about 60 RPM and nearly worthless. Stickler Log Splitter on Dingo
Apparently the yellow stickler ones are hollow. They are cheaper which was making be lean that way and they are made to bolt on a wheel hub which would make it a perfect combination with a wheel motor.
Also, Stickler was the only company that emailed me back when I asked about what RPM and power was needed. They did say that if you run it too fast it will get hot and cause the welds to fail. That sounds kind of odd. Can't get that hot I wouldn't think.
rosewood
« Reply #10 on: April 14, 2011, 07:30:59 PM »
rsi, i have afew different old motors...haven't looked up any specs on anything yet. some videos i've seen has steam coming off cone as it goes through wet wood, bet it does get pretty hot!
« Reply #11 on: April 14, 2011, 07:50:54 PM »
I just found the email from Stickler.
Quote
The Stickler requires about 150-200 RPM to be effective
bruey
« Reply #12 on: April 22, 2011, 06:56:32 PM »
rosewood, i have an auger for my bobcat and was going to try to use it and  jerry rig onto the end of it, if you figure it out let me no, they look sweet and sitting and spliting does seem nice. i priced one and they want close to 4000 and that wont fly in my house.
Newrichmond, Ohio
« Reply #13 on: April 22, 2011, 07:47:09 PM »
http://cgi.ebay.com/Screw-Type-Log-Splitter-Powered-Skid-Steer-Auger-/220738368001?pt=LH_DefaultDomain_0&hash=item3365083201
Guru
    • Mike's Advanced Heating
« Reply #14 on: April 27, 2011, 07:03:11 AM »
I got a cone splitter for sale.  It is a Bark Buster.  All it needs is a pto shaft.  I decided to persue a hydraulic 4 way log splitter with a log lift.
Mike
Caro MI
Pages: [1] 2 3
