Outdoor Wood Furnace Info
News
Home
Help
Search
Login
Register
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Username:
Password:
All-Purpose OWF Discussions
Equipment
screw cone splitter
« previous
next »
Pages:
1
2
3
Print
Author
Topic: screw cone splitter (Read 40841 times)
Hero Member
Offline
OWF Brand: HeatMaster
OWF Model: G200 and B250
Re: screw cone splitter
Reply #15 on:
April 27, 2011, 09:07:30 AM »
How much do you want for it?
Guru
Jr. Member
Offline
Reply #16 on:
April 27, 2011, 09:47:33 AM »
$100 will take it.
Mike
Caro MI
Hero Member
Offline
Reply #17 on:
April 27, 2011, 10:24:21 AM »
Quote from: Guru on April 27, 2011, 09:47:33 AM
$100 will take it.
PM sent
rosewood
Full Member
Offline
Reply #18 on:
July 25, 2011, 08:32:12 PM »
Haven't checked site in a while,but Im still on the cone kick! Got a friend who might be able to get me a hydraulic auger set up. So been holding off on buying cone till I get that. Also recently added mini excavator to toy box ,has extra plummed hyd and quick coupler so will be a easy build. With temps over a 100 yesterday who wants to think about wood.
Hero Member
Offline
Reply #19 on:
July 25, 2011, 09:31:20 PM »
I put one together with a stickler cone and hydraulic wheel motor. I am disappointing with the way it works. Luckily I made it for the skid steer and not for the RTV.
The hydraulic motor should be putting out about 32 hp and it gets stuck fairly easily. I was only able to split short wood with it too or it gets stuck. I have an oak log that is maybe 36" in diameter and probably only 4' long. It couldn't even peel a small chunk off the side without getting stuck.
It is possible that the hydraulic motor is warn out and not putting out that much HP any more but the wheel adapter for it is way too weak. I had to be really careful to not completely destroy it and only split a small pile of wood. I bent it several times and had a good 3"+ wobble in it.
I am going to have to almost completely redo it with the cone from Guru if I want it to split much wood.
Not sure yet if it will be worth the work or just start making a regular splitter.
rosewood
Full Member
Offline
Reply #20 on:
July 26, 2011, 07:00:04 PM »
Rsi, do you have any type of gearbox in between hyd motor and cone . If not ,you most likely won't ever see peak hp of motor. You will have to gear it some how.
Hero Member
Offline
Reply #21 on:
July 26, 2011, 07:33:08 PM »
I sized the motor to the speed I wanted. Isn't that pretty much the same difference as gearing it down?
rosewood
Full Member
Offline
Reply #22 on:
August 02, 2011, 06:57:05 PM »
RSI ,what are you powering the motor with? Most skidsters with extra hydraulics are any where from 15 to 20 gpm.
Hero Member
Offline
Reply #23 on:
August 02, 2011, 07:00:29 PM »
It is a Gehl Skid Steer. I believe it is about 17GPM and 2750 PSI.
I calculated the motor to be about 18 CU IN.
bruey
Full Member
Offline
Reply #24 on:
August 30, 2011, 07:38:04 PM »
i was reading on line and it said you cannot put the squealer on a bobcat auger attachment, they said the gear on the auger is not strong enough to turn it and it will stop, anybody here of this, if this is true i am back to square one.
Newrichmond, Ohio
tulenutn2o
Sr. Member
Offline
OWF Brand: HeatSource1
OWF Model: Earth Energy 190
Reply #25 on:
August 31, 2011, 06:17:37 PM »
I have one that I run off tractor pto and love it for the big logs.
bruey
Full Member
Offline
Reply #26 on:
September 01, 2011, 07:04:14 PM »
i have seen those but i think my bobcat would be so much quicker but if it wont work i sure dont want to spend the money, does anyone know?
Newrichmond, Ohio
Hero Member
Offline
Reply #27 on:
September 01, 2011, 07:07:47 PM »
Are you wanting to use it on a post hole digger? If so, what RPM does it run?
bruey
Full Member
Offline
Reply #28 on:
September 02, 2011, 04:42:49 PM »
no i would prefer to use my bobcat auger, i think it would be quicker than my tractor
Newrichmond, Ohio
tulenutn2o
Sr. Member
Offline
Reply #29 on:
September 19, 2011, 06:29:26 PM »
I believe the cone will fit the skid loader auger shaft too. It uses a standard size auger shaft doesn't it?. If so, I think a couple hundred bucks and you're in.
Print
Pages:
1
2
3
« previous
next »
Equipment
screw cone splitter
